Rayger 14 Posted February 26, 2017 Posted February 26, 2017 Lately I am having an overlay issue with Emby Theater Desktop. The top part of the overlay does not connect to the top of the screen, and there is a black box in the lower right corner. I am having trouble identifying what the issue is.
AdrianW 1058 Posted February 26, 2017 Posted February 26, 2017 I have the same issue with the top of the overlay - but only when running in a window, it's fine in fullscreen.
pir8radio 1313 Posted February 26, 2017 Posted February 26, 2017 I posted about this a long time ago, just watched a movie on ET tonight and noticed this has been fixed on mine.
Luke 42243 Posted February 26, 2017 Posted February 26, 2017 The top portion is not fixed in windowed mode. I am looking at resolving that, thanks.
Rayger 14 Posted February 26, 2017 Author Posted February 26, 2017 I have the issue in both windowed and maximized mode. I am more concerned with the black box in the lower right corner. It is always there, even when the overlay goes away.
Luke 42243 Posted February 26, 2017 Posted February 26, 2017 do you happen to have another windowed application that might be positioned right there?
Rayger 14 Posted February 27, 2017 Author Posted February 27, 2017 (edited) No other applications open. I have this black square every time with Emby Theater Desktop. Even after resetting. Also, I am sure it is a part of Emby, because if I set the window just right... I can get the overlay to appear on one monitor, and the video display to appear on another monitor without the black square. It definitely has something to do with the overlay. Edited February 27, 2017 by nnylray
Rayger 14 Posted March 17, 2017 Author Posted March 17, 2017 Is there anyway to follow up on this issue? It is still persisting, and I cannot figure out why.
Luke 42243 Posted March 17, 2017 Posted March 17, 2017 What is your windows resolution and also system dpi setting?
Rayger 14 Posted March 18, 2017 Author Posted March 18, 2017 That's a good question. I will check when I get home. I will also play around with the DPI settings and see if that's what caused it in the first place.
Rayger 14 Posted March 18, 2017 Author Posted March 18, 2017 The DPI was it! Thank you. I had the Text size in Display Settings raised to 175% since it's the TV. When I lower it to 150%, the black square disappears. When I lower it to 125%, the overlay lines up correctly with the window. Resolution is 1920 x 1080.
Luke 42243 Posted May 1, 2017 Posted May 1, 2017 @@nnylray The next release of Emby Theater will feature improved performance, hardware acceleration, and better multi-monitor support. If you'd like to try it out ahead of time you can do so here: https://emby.media/community/index.php?/topic/46763-theater-mpv-test/page-1 Enjoy.
