chali 11 Posted February 24, 2017 Posted February 24, 2017 Hi i shifted router yesterday, and today Emby refuse to enable https port as external port? tride multiple enable/disable https, reboots, and multiple ports its only http ports that seem to work. /Regards logg.txt
Luke 42245 Posted February 24, 2017 Posted February 24, 2017 Your cert if failing to load: 2017-02-24 19:55:15.1565 Error App: Error loading cert from /var/lib/emby-server/ssl/cert_54522e99effc77b8a5bc7ed2e196033b.pfx Fyi - I notice you've already updated to mono 4.8 and please be aware we haven't tested it yet. It was just released yesterday.
chali 11 Posted February 26, 2017 Author Posted February 26, 2017 Your cert if failing to load: 2017-02-24 19:55:15.1565 Error App: Error loading cert from /var/lib/emby-server/ssl/cert_54522e99effc77b8a5bc7ed2e196033b.pfx Fyi - I notice you've already updated to mono 4.8 and please be aware we haven't tested it yet. It was just released yesterday. a ok, do you know of a easy command for rolling back mono? /Regards
tassos00 0 Posted February 28, 2017 Posted February 28, 2017 Hi, I am experiencing the same problem. My emby-server works fine with http, but refuses to enable https and throws the same error message Error loading cert from /var/lib/emby-server/ssl/cert_54522e99effc77b8a5bc7ed2.........pfx and indeed it seems related to the mono version. The current version installed is 4.8.0. I checked the older log files and the error does not show up when Mono version 4.6.2 was installed. I am currently running emby-server version 3.2.5.0, mono version 4.8.0 on Ubuntu 64-bit 16.04 LTS /Best
Luke 42245 Posted February 28, 2017 Posted February 28, 2017 Hi, we are only just starting to test mono 4.8. Until we've gone through it fully, the latest 4.6.2.X is the recommended version.
chali 11 Posted March 9, 2017 Author Posted March 9, 2017 Any one now of a simple way to roolback mono? Skickat från min SM-G935F via Tapatalk
mvheezik 2 Posted March 11, 2017 Posted March 11, 2017 Is this issue fixed. I seem to have the same problem. My logfiles are filling up.
Luke 42245 Posted March 11, 2017 Posted March 11, 2017 Is this issue fixed. I seem to have the same problem. My logfiles are filling up. @@mvheezik, not yet, we are currently testing mono 4.8. Thanks !
