bigjohn 754 Posted February 5, 2014 Posted February 5, 2014 Currently you can only see image thumbnails in the metadata editor. It would be great if you could click the image and have it open in a new tab/window. Hard to see details of primary images when they are reduced from 680x1000 to 147x216. Thanks for your consideration! 5
bigjohn 754 Posted January 5, 2015 Author Posted January 5, 2015 This would also be nice so I could easily "save image as" instead of having to go find the image in the file system. Say I want to add background images or a primary image for a collection and could find them easily from the items within the collection, save them, then upload to the collection's images. 1
bigjohn 754 Posted January 6, 2015 Author Posted January 6, 2015 Probably should be a separate request, but the ability to change image type or copy an image to another type would be nice too. For instance, I sometimes use the interface to upload images and forget to change the type from primary to backdrop, so it would be cool to just change the type instead of having to upload it again. Or if I want to use a primary image as a backdrop as well, I could just copy it.
