AdrianW 1058 Posted July 31, 2018 Posted July 31, 2018 (edited) +1, I endured some seriously high volumes by accident by touching the wrong part of the screen. Would be great to be able to disable this feature. Thanks! There's a current bug that sets the volume straight to 100% as soon as you begin to swipe up or down on the right side. When this is fixed it shouldn't be as much of a problem. Edited August 1, 2018 by AdrianW
Luke 42245 Posted July 31, 2018 Posted July 31, 2018 It's resolved in the next update to the app. Thanks. 1
okEric 2 Posted August 2, 2018 Posted August 2, 2018 It's resolved in the next update to the app. Thanks.Thank goodness, I think my hearing might be damaged (not really) from the sudden full blast of audio.
okEric 2 Posted August 13, 2018 Posted August 13, 2018 Is this gonna be fixed soon? The volume is going full blast if I accidentally touch the right portion of my screen. It's rather scary actually.
AdrianW 1058 Posted August 14, 2018 Posted August 14, 2018 Is this gonna be fixed soon? The volume is going full blast if I accidentally touch the right portion of my screen. It's rather scary actually. There was an update in the PlayStore a few days ago, it's fixed the volume control issue for me (at least I can now raise and lower the volume instead of just setting it directly to max).
AdrianW 1058 Posted August 15, 2018 Posted August 15, 2018 Actually on a fresh start of the app - the first touch on the right will put the volume straight up to 100% and from then on it will work correctly lowering or raising the volume without instant jumps.
darkassassin07 674 Posted August 15, 2018 Posted August 15, 2018 (edited) I can confirm this is currently the case with version 3.0.9 (beta), at least on my device Edited August 15, 2018 by darkassassin07
dqspider 0 Posted September 27, 2018 Posted September 27, 2018 Actually on a fresh start of the app - the first touch on the right will put the volume straight up to 100% and from then on it will work correctly lowering or raising the volume without instant jumps. Same here on my S9+ and my wife's S9+ as well. Also I would like to add my vote for an option to disable the touch brightness and volume
poweld 0 Posted December 26, 2018 Posted December 26, 2018 The immediate jump to max brightness and, more dangerously, max volume, is definitely still present on the Android client. This feature doesn't really appeal to me in the first place, and the risk to my hearing has really deterred me from using Emby on Android. It's disappointing that this bug has been known for nearly two years now, and still the feature it affects has not been fixed or disabled. Any potential convenience the feature may add is outweighed by the fact that it is not functioning as intended. Have you guys been able to replicate this through test suites? Is the issue only with certain devices? Some more information might help us understand what progress is being made. If more info is needed from us, I'm sure people who have participated in this thread are happy to help.
Luke 42245 Posted January 2, 2019 Posted January 2, 2019 @@poweld, apologies for the delay on resolving this. We're looking into it for the next update to the app. Thanks.
ian78 3 Posted January 6, 2019 Posted January 6, 2019 Yeah this is a deal breaker for me as well, can’t use this app as it’s too dangerous the way it is
Luke 42245 Posted January 6, 2019 Posted January 6, 2019 This is resolved for the next update to the app. Thanks.
Luke 42245 Posted January 11, 2019 Posted January 11, 2019 This is released to the app store and resolved in 3.0.29+. Thanks ! 1
neik 874 Posted January 11, 2019 Posted January 11, 2019 @@Luke, I noticed that whenever one adjust the volume or the brightness the OSD appears. My suggestion would be to not show the OSD while adjusting the volume/brightness. What do you think?
Luke 42245 Posted January 11, 2019 Posted January 11, 2019 How would you know if you've reached the max brightness level?
neik 874 Posted January 12, 2019 Posted January 12, 2019 (edited) Here is a missunderstanding I guess. I was talking about the highlighted part on this Screenshot: https://abload.de/img/screenshot_2019-01-12zcezc.png That part isn't really needed when adjusting the brightness level, right? €dit: The other small window indicating the brightness, that is absolutely needed to know when you hit the max. This is on 3.0.30 Edited January 12, 2019 by neik
GavinAshford 1 Posted January 12, 2019 Posted January 12, 2019 Since this lastest update the volume indicator hasn't shown up for me when swiping to adjust volume. The brightness one still does. This is on a Google Pixel 2 XL (with system display size setting set to small).
Luke 42245 Posted January 12, 2019 Posted January 12, 2019 I removed the custom volume OSD but i'd like to have the system volume OSD show in that situation. So that's something we'll need to look at. Thanks. 1
GavinAshford 1 Posted January 13, 2019 Posted January 13, 2019 That'd explain it then! Thanks for clarifying
poweld 0 Posted February 8, 2019 Posted February 8, 2019 I should have posted earlier, but sometimes life gets in the way. @@Luke credit where credit is due, the problem has been mitigated or resolved, depending on whether you plan on reimplementing it in the future. I've begun using Emby on Android once again because of it. My ears thank you.
