chjohans 34 Posted February 23, 2017 Posted February 23, 2017 I currently have my Emby server configured storing metadata in it's own folder, as opposed to with the media. I'm using MCM to download some metadata which is stored with the media. Anyhow, if I configure Emby to store metadata with the meida then what kind of metadata will it store with my media, eg type and naming convention so I know what to expect. And what will it still store centralized? I assume "people" and "chapter extractions" at least? I've tried so search for this info but couldn't find it anywhere.
mastrmind11 722 Posted February 23, 2017 Posted February 23, 2017 -rw-rw-r-- 1 emby emby 1972136 Oct 1 11:24 X-Men.Apocalypse.2016.x264.DTS-fanart.jpg -rw-rw-r-- 1 emby emby 747508 Oct 1 11:24 X-Men.Apocalypse.2016.x264.DTS-landscape.jpg -rw-rw-r-- 1 emby emby 160114 Oct 1 11:24 X-Men.Apocalypse.2016.x264.DTS-logo.png -rwxrwxr-x 1 emby emby 8213623596 Sep 9 10:58 X-Men.Apocalypse.2016.x264.DTS.mkv -rwxrwxr-x 1 emby emby 13589 Feb 3 17:24 X-Men.Apocalypse.2016.x264.DTS.nfo -rw-rw-r-- 1 emby emby 1419627 Oct 1 11:24 X-Men.Apocalypse.2016.x264.DTS-poster.jpg
Luke 42197 Posted February 23, 2017 Posted February 23, 2017 Yes i haven't looked at MCM lately but most likely the same file names. Our wiki does cover some accepted file names: https://github.com/MediaBrowser/Wiki/wiki/Movie%20naming
Happy2Play 9802 Posted February 23, 2017 Posted February 23, 2017 MCM and Legacy Image Saving setting All metadata and images with media. And what will it still store centralized? I assume "people" and "chapter extractions" at least? Yes
chjohans 34 Posted February 25, 2017 Author Posted February 25, 2017 Ok thanks, just what I needed. Looks like it's no problem to keep MCM for initial metadata download and then let Emby take it from there. 1
Happy2Play 9802 Posted February 25, 2017 Posted February 25, 2017 Ok thanks, just what I needed. Looks like it's no problem to keep MCM for initial metadata download and then let Emby take it from there. I haven't had any real issues. 1
Happy2Play 9802 Posted February 26, 2017 Posted February 26, 2017 (edited) I must note even though it isn't really functional I still have the xmlmetadata plugin installed also. Library-Metadata - each content type reader order xml then nfo Edited February 26, 2017 by Happy2Play
chjohans 34 Posted February 26, 2017 Author Posted February 26, 2017 Ah, I missed the post regarding how Emby now does not read metadata from the xml-file by default. I guess I should install this plugin as well. Can't find it in the online cataloge so I guess I'll have to search the plugin forum section for it. Thanks for making me aware of this.
chjohans 34 Posted February 26, 2017 Author Posted February 26, 2017 Hmm searched the plugin forum but can't find the xml metadata plugin there, can't find it in the online catalog either. Am I missing something?
Luke 42197 Posted February 26, 2017 Posted February 26, 2017 The xml saver plugin has been removed from the catalog until we can find a new volunteer to maintain it. I would suggest sticking with our default nfo format as that is where pretty much all of our testing is going. Thanks.
chjohans 34 Posted February 26, 2017 Author Posted February 26, 2017 Ok, but Emby will still *read* the xml files if they exist right? And according to the read order as configured on the server?
