QuasiZ 4 Posted February 22, 2017 Posted February 22, 2017 Well, crap. Might have celebrated a little too soon in another post. Emby just locked up in the same way that Plex likes to lock up on me - in that it becomes unresponsive and I can't shut it down; not even the process, as that reports "Access denied" (yes, I'm admin. Yes, I've tried that one tool that may point to a driver that somehow has a lock on it and yes it came up empty.. but I'm not a system guru, so I'd be happy to go through it again), requiring a full reboot to fix. At least with Emby it was preceded by an error.. which I fully acknowledge may be completely unrelated: System.ArgumentException: Source array was not long enough. Check srcIndex and length, and the array's lower bounds. at System.Array.Copy(Array sourceArray, Int32 sourceIndex, Array destinationArray, Int32 destinationIndex, Int32 length, Boolean reliable) at System.Collections.Generic.List`1.set_Capacity(Int32 value) at System.Collections.Generic.List`1.EnsureCapacity(Int32 min) at System.Collections.Generic.List`1.Add(T item) at Emby.Server.Core.EntryPoints.ExternalPortForwarding.<CreateRules>d__19.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.AsyncMethodBuilderCore.<>c.<ThrowAsync>b__6_1(Object state) at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx) at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx) at System.Threading.QueueUserWorkItemCallback.System.Threading.IThreadPoolWorkItem.ExecuteWorkItem() at System.Threading.ThreadPoolWorkQueue.Dispatch() System.ArgumentException at System.Array.Copy(Array sourceArray, Int32 sourceIndex, Array destinationArray, Int32 destinationIndex, Int32 length, Boolean reliable) at System.Collections.Generic.List`1.set_Capacity(Int32 value) at System.Collections.Generic.List`1.EnsureCapacity(Int32 min) at System.Collections.Generic.List`1.Add(T item) at Emby.Server.Core.EntryPoints.ExternalPortForwarding.<CreateRules>d__19.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.AsyncMethodBuilderCore.<>c.<ThrowAsync>b__6_1(Object state) at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx) at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx) at System.Threading.QueueUserWorkItemCallback.System.Threading.IThreadPoolWorkItem.ExecuteWorkItem() at System.Threading.ThreadPoolWorkQueue.Dispatch() Given the terminology there (port forwarding), I disabled all the DLNA things and hope for the best. Would be happy to give more information if requested.
Luke 42197 Posted February 22, 2017 Posted February 22, 2017 Hi, I think I know why this is happening. i am adding a change for the next release. thanks ! 1
