legallink 187 Posted February 22, 2017 Posted February 22, 2017 On the apple TV, when we are watching a TV series, towards the end of the current episode, a "next up" dialog appears, which is great. However, if you don't click on the "Play Next" dialog (I don't remember exactly what the wording is) or "Cancel", the next expisode starts....which is fine. The problem is that the dialog doesn't go away if you don't click anything, and if you click on the dialog after it has started the next episode, then it skips another one forward, meaning you have to back out of the episode playing and start over....thus defeating the whole purpose. Thoughts?
corey 317 Posted February 22, 2017 Posted February 22, 2017 Hey @@legallink -- I noticed this issue a few weeks ago and I believe I pushed a fix but it hasn't been released to production yet. I'm not sure when @@ebr plans to push out the couple of bug fixes we've made recently.
legallink 187 Posted February 22, 2017 Author Posted February 22, 2017 thanks @@corey. I'll keep my eyes peeled to see what happens on the update front.
ebr 16335 Posted February 23, 2017 Posted February 23, 2017 If either of you have a working testflight version, can you confirm everything is okay with it?
legallink 187 Posted February 23, 2017 Author Posted February 23, 2017 @@ebr I need to be re-invited to test flight.
ebr 16335 Posted February 23, 2017 Posted February 23, 2017 I think the current version just expired. I'll push out to production as the changes were minor and should be fine (and Corey has tested them). Thanks.
