markm75 3 Posted February 5, 2014 Posted February 5, 2014 Running MBC and I cant seem to get parental ratings to work for seasons under a title.. If i set the root element to a rating.. it then doesnt show up for that whole title.. fine.. but if i only want say season 3 and season 4 to have a higher rating, i set this in the meta tool and go back to MBC and those seasons still appear in the listing for my parental locked user.. Any thoughts here? Thanks
markm75 3 Posted February 5, 2014 Author Posted February 5, 2014 I see the issue in the server. I will fix it for the next release. ok great.. thanks for checking
ebr 16332 Posted February 6, 2014 Posted February 6, 2014 This could be tricky because, in 99% of cases, you want any season of a TV show to inherit the rating of the show itself. Same for episodes as that data is not normally defined anywhere except the Series level.
Luke 42239 Posted February 6, 2014 Posted February 6, 2014 Agreed. It's the custom rating value that is looking at the series first, so i think the fix ist here.
Luke 42239 Posted February 6, 2014 Posted February 6, 2014 I see the issue in the server. I will fix it for the next release.
