Icepick 1 Posted February 22, 2017 Posted February 22, 2017 Hello I am using the web interface. I use the next up feature all the time but have notice that for some reason only the TV show The Flash 2014 doesn't appear on there, as pictured below. As you can see The Flash S03E13 isn't there. As you can see if I open The Flash 2014 TV folder in Emby it shows the episode The Flash S03E13 is there.
Luke 42197 Posted February 22, 2017 Posted February 22, 2017 hi @@Icepick. the next up screen always has a limit to the number of items it will show, so there is a good chance that is why you're not seeing that episode.
Icepick 1 Posted February 22, 2017 Author Posted February 22, 2017 hi @@Icepick. the next up screen always has a limit to the number of items it will show, so there is a good chance that is why you're not seeing that episode. Thanks for the reply. I'm not to sure if that is the problem as this is a friends of mine problem which I don't have. As you can see from the below picture of my Next Up I have 10 item in the picture and another 14 after scrolling down. Which is a total of 24, where as his is only 4.
Happy2Play 9802 Posted February 22, 2017 Posted February 22, 2017 Does it show up on Latest page? Only thing I can think of is it may me metadata related. Can you click on that episode of The Flash and post a screenshot.
Icepick 1 Posted February 24, 2017 Author Posted February 24, 2017 Does it show up on Latest page? Only thing I can think of is it may me metadata related. Can you click on that episode of The Flash and post a screenshot. Yes it does. All other shows show up in Next up ect The Flash? The Meta for The Flash looks ok?
Icepick 1 Posted February 25, 2017 Author Posted February 25, 2017 (edited) Does the episode have a season number? For some reason in the meta screenshot it didn't show season number but does now. Edited February 25, 2017 by Icepick
Icepick 1 Posted February 25, 2017 Author Posted February 25, 2017 Also has the season number on the season folder meta It only effects all of The Flash episode.
Happy2Play 9802 Posted February 25, 2017 Posted February 25, 2017 Have you tried a Refresh at Series or Season Level?
Icepick 1 Posted February 25, 2017 Author Posted February 25, 2017 Have you tried a Refresh at Series or Season Level? I think a full refresh for the TV show fixed.
Icepick 1 Posted February 26, 2017 Author Posted February 26, 2017 Thanks for the report. Thanks for the help mate.
kingy444 117 Posted February 26, 2017 Posted February 26, 2017 @@Luke possible to have the limit on the 'Next Up' section added as a variable on the server backend. Perhaps as part of the library settings so if can be configured per library ?
Happy2Play 9802 Posted February 27, 2017 Posted February 27, 2017 @@Luke possible to have the limit on the 'Next Up' section added as a variable on the server backend. Perhaps as part of the library settings so if can be configured per library ? There are posts on which JS files (homeupcoming.js, tvupcoming.js) you can modify the limit:40 but they are reset with every update. A issue I have noticed doing this is the information gets cached and if a item gets updated on a provider site you don't get that updated without manually refreshing the show that changed.
kingy444 117 Posted February 27, 2017 Posted February 27, 2017 time to time I fall behind. If its set to 40 that's probably plenty
