pcgirl 4 Posted February 22, 2017 Posted February 22, 2017 I am currently running Kodi 16.1 with Emby 2.3.46. Everything had been working great until recently when I try to start some TV Shows or Movies I am getting a Playback Error. I thought it was just a particular file but then it happened with a different file. So I have attached the log file. Some help would be greatly appreciated. Thanks!kodi.log
hoppel118 37 Posted February 22, 2017 Posted February 22, 2017 (edited) Sorry, wrong thread... Edited February 22, 2017 by hoppel118
Festivus Oz 0 Posted February 22, 2017 Posted February 22, 2017 If you recently upgraded to emby server 3.2.0.0 your issue is likely it has removed your path substitutions. You need to read them under Library | [source I.E. TV] | Manage Folders | (Optional) Shared Network Folder Sent from my ONEPLUS A3010 using Tapatalk
pcgirl 4 Posted February 22, 2017 Author Posted February 22, 2017 I can't find the (Optional) Shared Network Folder. It is showing my network folder location though.
Luke 42242 Posted February 22, 2017 Posted February 22, 2017 hi @@pcgirl, click on your existing /mnt/user/tv shows path. Let us know if this helps. thanks !
pcgirl 4 Posted February 22, 2017 Author Posted February 22, 2017 Do I have to set this as the same /mnt/user/TV Shows?
CharleyVarrick 284 Posted February 23, 2017 Posted February 23, 2017 (edited) The first path (in bold) is the mapped drive path (think of this one has the shortcut), the one you need to add is the complete network path, basically adding "\\computer name" in front. Note that my system runs Windows, but its the same general idea. Edited February 23, 2017 by jlr19
Luke 42242 Posted February 23, 2017 Posted February 23, 2017 @@pcgirl, let us know if this helps. thanks !
pcgirl 4 Posted February 23, 2017 Author Posted February 23, 2017 I will let you know but I haven't been able to test it as of yet. However, my server is an Unraid server so I think that the Network path is the same or similar to what I have in the first path. I will check this tonight.
Luke 42242 Posted February 23, 2017 Posted February 23, 2017 Ok, there would be no reason to enter the same value in both fields, fyi.
CharleyVarrick 284 Posted February 24, 2017 Posted February 24, 2017 (edited) Not sure what's an Unraid server, but I wonder how "/mnt/user/tv shows" could mean anything to a client Edited February 24, 2017 by jlr19
pcgirl 4 Posted February 24, 2017 Author Posted February 24, 2017 Yes, you are right. I had to set it to \\Server\TV Shows and \\Server\Movies. It seems to be working now. Thanks for the help.
