ebr 16332 Posted February 5, 2014 Posted February 5, 2014 I need some help from those of you that are having this problem because I cannot reproduce it so I can't figure out how to fix it. Can everyone having this problem please post the following information: - The view style you have selected for your TV Series collection - A screen shot of these two config pages: Thanks.
bigjohn 754 Posted February 5, 2014 Posted February 5, 2014 @@ebr, let me know if you need any more info. Series view options: Thumb > Backdrops > LabelsTV Collection-level options: Poster > Labels > Vertical ScrollView Options Screen:Chocolate Views Screen:Series when entered for first time:Back out, re-enter series:
ebr 16332 Posted February 5, 2014 Author Posted February 5, 2014 Thanks but I got lost - what is the difference between the "Series View" and the "TV Collection Level View"? Do you have your series grouped into sub-folders?
bigjohn 754 Posted February 5, 2014 Posted February 5, 2014 (edited) Click on TV collection from EHS takes you to TV collection-level view (shows all TV series). Should have probably called it MB3 Media Folder level. Click on a series takes you to series view. Edited February 5, 2014 by bigjohn
ebr 16332 Posted February 5, 2014 Author Posted February 5, 2014 Okay, I got confused because at the Series view level it would be the special TV view, but you said you had it set to "Thumb". In any case, can you please try this version of Chocolate just in case it helps. 1
bigjohn 754 Posted February 5, 2014 Posted February 5, 2014 Right, I thought it would go without saying that I was using the special TV view since that is where the problem is occurring. I was reporting the series view settings because you asked for them The only way to get to them is by disabling the special view of course. Sorry for the confusion. I will try this version of Chocolate and let you know shortly. This place is adding to my waistline because we keep talking about Chocolate.
bigjohn 754 Posted February 5, 2014 Posted February 5, 2014 This new version of Chocolate seems to have done the trick. All of my TV series work as they should the first time.
