maegibbons 1287 Posted February 20, 2017 Posted February 20, 2017 Hi If you pause something you are watching, emby eventually times out and takes you back to the detail screen of the item - which is fine. HOWEVER the focus is on the play icon rather than the resume. If you are not careful you start playing the item from the beginning loosing the resume point. When it times out back to the detail screen it should set the focus to resume rather than play. Small issue but would help with usability. And whilst talking usability I will bring back up the the fact that "trash can" should be available next to play when a program has ended naurally. This is particularly true of recorded tv content. Most common action is tp delete it when watched. Krs Mark
ebr 16337 Posted February 20, 2017 Posted February 20, 2017 What is actually happening here is the device screen saver is kicking in which is pausing our entire app. I can look to see if it is possible to deal with the focus in that situation though.
maegibbons 1287 Posted February 20, 2017 Author Posted February 20, 2017 Yes you are, as always, correct. The screen saver is indeed kicking in. Thanks for looking at it.
