Guest asrequested Posted March 2, 2017 Posted March 2, 2017 (edited) It's the folder nesting. I raised the movie file one level at a time and played. It always direct streamed until I got to the top level, then it direct played. Update: Resume doesn't work. There's no sound and an almost frame by frame motion....slowly Edited March 2, 2017 by Doofus
Guest asrequested Posted March 2, 2017 Posted March 2, 2017 (edited) There's an issue with the m2ts container. I remuxed to MKV, no change to the contents, just a container change. Plays and resumes just fine. EDIT: I did remove the subs EDIT 2: Remuxed one more time, and left all contents unchanged. Plays and resumes just fine. Edited March 2, 2017 by Doofus
Guest asrequested Posted March 2, 2017 Posted March 2, 2017 To recap: BD rip with the video file in nested folders will transcode/direct stream m2ts file container has resume issue.
mentasm 43 Posted March 2, 2017 Posted March 2, 2017 (edited) @ Deleted the LAV folder and restarted ET and it hasn't re-downloaded the folder. Tested a file. Same issue still persists. Shows as Transcoding in emby dashboard. All files are stored locally on hard disks in the media centre Edited March 2, 2017 by mentasm
Guest asrequested Posted March 2, 2017 Posted March 2, 2017 @ Deleted the LAV folder and restarted ET and it hasn't re-downloaded the folder. Tested a file. Same issue still persists. Shows as Transcoding in emby dashboard. All files are stored locally on hard disks in the media centre What files are you playing and what are your theater settings
mentasm 43 Posted March 2, 2017 Posted March 2, 2017 (edited) @ x264 480p mp4 file. I'm not sure that I'm running much other than default ET settings. HW accel set to auto MadVR renderer stable filter set no changing refresh rate See this in server log: 2017-03-02 17:37:52.4233 Info HttpServer: HTTP POST http://localhost:8096/emby/Items/3f1cceaefe3a5ca1ab461ad81505750c/PlaybackInfo?UserId=987237e1a2d34b36a0f6330fa3817c46&StartTimeTicks=16832993335&MaxStreamingBitrate=919540. UserAgent: Mozilla/5.0 (Windows NT 6.1; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) EmbyTheater/2.5.38 Chrome/53.0.2785.143 Electron/1.4.15 Safari/537.36 2017-03-02 17:37:52.4233 Info App: Bitrate exceeds DirectPlay limit: media bitrate: 1165155, max bitrate: 919540 2017-03-02 17:37:52.4233 Info App: Profile: Unknown Profile, Path: E:\TV Shows\Glitch (2015)\Season 01\Glitch (2015) - S01E02 - Episode 2.mp4, isEligibleForDirectPlay: True, isEligibleForDirectStream: False 2017-03-02 17:37:52.4233 Info App: Bitrate exceeds DirectPlay limit: media bitrate: 1165155, max bitrate: 919540 2017-03-02 17:37:52.4233 Info App: Profile: Unknown Profile, Path: E:\TV Shows\Glitch (2015)\Season 01\Glitch (2015) - S01E02 - Episode 2.mp4, isEligibleForDirectPlay: True, isEligibleForDirectStream: False 2017-03-02 17:37:52.4233 Info App: Bitrate exceeds DirectPlay limit: media bitrate: 1165155, max bitrate: 919540 2017-03-02 17:37:52.4233 Info App: Profile: Unknown Profile, Path: E:\TV Shows\Glitch (2015)\Season 01\Glitch (2015) - S01E02 - Episode 2.mp4, isEligibleForDirectPlay: True, isEligibleForDirectStream: False 2017-03-02 17:37:52.4233 Info HttpServer: HTTP Response 200 to ::1. Time: 4ms. http://localhost:8096/emby/Items/3f1cceaefe3a5ca1ab461ad81505750c/PlaybackInfo?UserId=987237e1a2d34b36a0f6330fa3817c46&StartTimeTicks=16832993335&MaxStreamingBitrate=919540 2017-03-02 17:37:55.7640 Info HttpServer: HTTP POST http://localhost:8096/emby/Sessions/Playing. UserAgent: Mozilla/5.0 (Windows NT 6.1; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) EmbyTheater/2.5.38 Chrome/53.0.2785.143 Electron/1.4.15 Safari/537.36 2017-03-02 17:37:55.7840 Info HttpServer: HTTP Response 204 to ::1. Time: 20ms. http://localhost:8096/emby/Sessions/Playing and ET logs: 2017-03-02 17:37:53.3743 Info App: Http POST directshowplayer/play 2017-03-02 17:37:53.9324 Info DirectShowPlayerBridge: Playing media source {"Protocol":"File","Id":"3f1cceaefe3a5ca1ab461ad81505750c","Path":"E:\\TV Shows\\Glitch (2015)\\Season 01\\Glitch (2015) - S01E02 - Episode 2.mp4","Type":"Default","Container":"mp4","Name":"480P/H264/AAC","ETag":"e02a80f6c7190f8ddd0aaf286288be8c","RunTimeTicks":31489480704,"ReadAtNativeFramerate":false,"SupportsTranscoding":true,"SupportsDirectStream":false,"SupportsDirectPlay":false,"IsInfiniteStream":false,"RequiresOpening":false,"RequiresClosing":false,"SupportsProbing":true,"VideoType":"VideoFile","MediaStreams":[{"Codec":"h264","CodecTag":"avc1","Language":"und","TimeBase":"1/25000","CodecTimeBase":"1/50","NalLengthSize":"4","IsInterlaced":false,"IsAVC":true,"BitRate":1016308,"BitDepth":8,"RefFrames":5,"IsDefault":true,"IsForced":false,"Height":404,"Width":718,"AverageFrameRate":25,"RealFrameRate":25,"Profile":"High","Type":"Video","AspectRatio":"16:9","Index":0,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"PixelFormat":"yuv420p","Level":31,"IsAnamorphic":false},{"Codec":"aac","CodecTag":"mp4a","Language":"und","TimeBase":"1/48000","CodecTimeBase":"1/48000","DisplayTitle":"Und AAC stereo Default","IsInterlaced":false,"ChannelLayout":"stereo","BitRate":144631,"Channels":2,"SampleRate":48000,"IsDefault":true,"IsForced":false,"Profile":"LC","Type":"Audio","Index":1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Level":0,"IsAnamorphic":false}],"PlayableStreamFileNames":[],"Formats":[],"Bitrate":1165155,"RequiredHttpHeaders":{},"TranscodingUrl":"/videos/3f1cceaefe3a5ca1ab461ad81505750c/stream.mkv?DeviceId=mediacentre&MediaSourceId=3f1cceaefe3a5ca1ab461ad81505750c&VideoCodec=h264&AudioCodec=mp3,ac3,aac&AudioStreamIndex=1&VideoBitrate=774909&AudioBitrate=144631&StartTimeTicks=16832993335&PlaySessionId=a0d3ee2096754c849e0f58b7c921be7b&api_key=949107985c17481b861c159d3845535b&CopyTimestamps=false&EnableSubtitlesInManifest=false&Tag=e02a80f6c7190f8ddd0aaf286288be8c&RequireAvc=false","TranscodingContainer":"mkv","DefaultAudioStreamIndex":1} 2017-03-02 17:37:53.9324 Info InternalDirectShowPlayer: Playing Episode 2. Audio Renderer: Default, Madvr: True, xySubFilter: True, ParentID: 3f0d1e0f55fdcecd812361fbd35869d6 2017-03-02 17:37:53.9324 Info InternalDirectShowPlayer: Playing Path E:\TV Shows\Glitch (2015)\Season 01\Glitch (2015) - S01E02 - Episode 2.mp4 2017-03-02 17:37:53.9974 Info InternalDirectShowPlayer: Configure LAV Splitter 2017-03-02 17:37:54.0114 Info InternalDirectShowPlayer: SetSubtitleMode: 2017-03-02 17:37:54.0114 Info InternalDirectShowPlayer: SetPGSForcedStream: False 2017-03-02 17:37:54.0114 Info InternalDirectShowPlayer: SetPGSOnlyForced: False 2017-03-02 17:37:54.3219 Info InternalDirectShowPlayer: GPU Model: Intel(R) HD Graphics Family 2017-03-02 17:37:54.3219 Info InternalDirectShowPlayer: Current HWA Mode: None Desired Mode: DXVA2CopyBack 2017-03-02 17:37:54.3219 Info InternalDirectShowPlayer: Current SW DI Mode: None Desired Mode: None 2017-03-02 17:37:54.8179 Info InternalDirectShowPlayer: SetAudioStreamIndex 1 2017-03-02 17:37:54.8179 Info InternalDirectShowPlayer: SetAudioStreamIndex 1. Track offset: 0 2017-03-02 17:37:54.8219 Info InternalDirectShowPlayer: SetInternalStream 1 Audio A: aac, 48000 Hz, stereo, 144 kb/s 2017-03-02 17:37:54.8219 Info InternalDirectShowPlayer: UpdateStreamActiveSetting name = 'A: aac, 48000 Hz, stereo, 144 kb/s' 2017-03-02 17:37:54.8409 Info InternalDirectShowPlayer: SetSubtitleStreamIndex: -1 2017-03-02 17:37:54.8409 Info InternalDirectShowPlayer: SetSubtitleStreamIndex -1. Track offset: -1 Edited March 2, 2017 by mentasm
Guest asrequested Posted March 2, 2017 Posted March 2, 2017 where are they? Same place as the server logs
mentasm 43 Posted March 2, 2017 Posted March 2, 2017 (edited) Only server logs in there > AppData\Roaming\Emby-Server\logs Edited March 2, 2017 by mentasm
Luke 42240 Posted March 2, 2017 Posted March 2, 2017 There's no problem with subfolders, it must be something related to permissions of the network share. See this example from the Theater log. 2017-03-02 02:17:22.9613 Info App: Http POST directshowplayer/play 2017-03-02 02:17:23.1569 Info DirectShowPlayerBridge: Playing media source {"Protocol":"File","Id":"49efcbf10a19dbcd77feafd9b2f01baf","Path":"E:\\Media\\Movies\\fgh1\\fghr","Type":"Default","Name":"Bluray","ETag":"543b6ca4c9f21c87d81daf7a932499c0","ReadAtNativeFramerate":false,"SupportsTranscoding":true,"SupportsDirectStream":false,"SupportsDirectPlay":false,"IsInfiniteStream":false,"RequiresOpening":false,"RequiresClosing":false,"SupportsProbing":true,"VideoType":"BluRay","MediaStreams":[],"PlayableStreamFileNames":[],"Formats":[],"RequiredHttpHeaders":{},"TranscodingUrl":"/videos/49efcbf10a19dbcd77feafd9b2f01baf/stream.mkv?DeviceId=DESKTOP-EIQIB3R&MediaSourceId=49efcbf10a19dbcd77feafd9b2f01baf&VideoCodec=h264&AudioCodec=mp3,ac3,aac&VideoBitrate=1371236571&AudioBitrate=192000&PlaySessionId=1e89dc1677a846e8ac81ed474c16785a&api_key=b9f698ca853748c99a15bdcad0b6cd16&CopyTimestamps=false&EnableSubtitlesInManifest=false&Tag=543b6ca4c9f21c87d81daf7a932499c0&RequireAvc=false","TranscodingContainer":"mkv"} 2017-03-02 02:17:23.2280 Info InternalDirectShowPlayer: Playing fghr. Audio Renderer: Default, Madvr: False, xySubFilter: True, ParentID: e2794bb4a2b64557b4d29220d206dfb5 2017-03-02 02:17:23.2280 Info InternalDirectShowPlayer: Playing Path E:\Media\Movies\fgh1\fghr 2017-03-02 02:17:23.2736 Info InternalDirectShowPlayer: Configure LAV Splitter 2017-03-02 02:17:23.2736 Info InternalDirectShowPlayer: SetSubtitleMode: 2017-03-02 02:17:23.2736 Info InternalDirectShowPlayer: SetPGSForcedStream: False 2017-03-02 02:17:23.2736 Info InternalDirectShowPlayer: SetPGSOnlyForced: False Theater was able to direct play because it had direct access to the folder path over the network.
Guest asrequested Posted March 2, 2017 Posted March 2, 2017 Only server logs in there > AppData\Roaming\Emby-Server\logs Then it's not transcoding. Do you see anything like this in the server?
mentasm 43 Posted March 2, 2017 Posted March 2, 2017 (edited) still no lav folder back in the COMObjects folder Edited March 2, 2017 by mentasm
Guest asrequested Posted March 2, 2017 Posted March 2, 2017 (edited) I think there's a glitch If it were transcoding, you'd have a red line with the green. Like this. Edited March 2, 2017 by Doofus
Guest asrequested Posted March 2, 2017 Posted March 2, 2017 still no lav folder back in the COMObjects folder Nothing will play, if LAV isn't there.
Luke 42240 Posted March 2, 2017 Posted March 2, 2017 still no lav folder back in the COMObjects folder I think this is just a playback reporting glitch but it appears to be direct playing to me.
mentasm 43 Posted March 2, 2017 Posted March 2, 2017 Nothing will play, if LAV isn't there. well it is and there isn't. No wonder I'm having issues. Should I uninstall ET and start fresh?
mentasm 43 Posted March 2, 2017 Posted March 2, 2017 I think this is just a playback reporting glitch but it appears to be direct playing to me. Any ideas on why when I resume watchign that episode in the screenshot it keeps starting at the beginning of the video instead of 29:26? Want the full Logs? I think I posted the pertinent sections above
Guest asrequested Posted March 2, 2017 Posted March 2, 2017 (edited) well it is and there isn't. No wonder I'm having issues. Should I uninstall ET and start fresh? Just reinstall over the top. It'll fill in the blanks. Or you can get it here https://github.com/Nevcairiel/LAVFilters/releases Edited March 2, 2017 by Doofus
mentasm 43 Posted March 2, 2017 Posted March 2, 2017 (edited) Rerinstalling that LAV stuff fixed it. Now shows direct play in dashboard and resumes at the right spot. Can also click on progress bar to nvigate forward and back Thanks! Edited March 2, 2017 by mentasm
Latchmor 584 Posted March 2, 2017 Posted March 2, 2017 Hi guys, I had to delete the whole COMObjects folder and it re-downloaded as soon as ET started. Deleting the LAV folder alone left me in the same situation as mentasm. Cheers
mentasm 43 Posted March 2, 2017 Posted March 2, 2017 tested that and it worked for me too. Now have a LAV folder back int here.
mystic.bertie 23 Posted March 2, 2017 Posted March 2, 2017 I too dont have any transcoding logs in the server folder.
Guest asrequested Posted March 2, 2017 Posted March 2, 2017 I too dont have any transcoding logs in the server folder. Aren't your files direct playing?
Guest asrequested Posted March 2, 2017 Posted March 2, 2017 Luke, isn't it supposed to see the LAV folder is gone and reacquire it?
