Guest asrequested Posted February 27, 2017 Posted February 27, 2017 I think the LAV filters probably got tweaked a little. I'm glad you got it working 1
mystic.bertie 23 Posted February 28, 2017 Posted February 28, 2017 I have this problem with ripped bluray movies, i cant skip forward using the slider or the forward buttons, it just goes back to the start. I removed ET and deleted the one ET folder, reinstalled ET, its still not working. I tried the 3 different video renderers and it still does not work.
thelangs 2 Posted February 28, 2017 Posted February 28, 2017 Check to see if the playback is "transcoding" or direct play 1
Guest asrequested Posted February 28, 2017 Posted February 28, 2017 (edited) I have this problem with ripped bluray movies, i cant skip forward using the slider or the forward buttons, it just goes back to the start. I removed ET and deleted the one ET folder, reinstalled ET, its still not working. I tried the 3 different video renderers and it still does not work.Can you post a screenshot of the file details? What did you rip the disc with? Edited February 28, 2017 by Doofus 1
mystic.bertie 23 Posted February 28, 2017 Posted February 28, 2017 Can you post a screenshot of the file details? What did you rip the disc with? What are the fine details ? It was a movie i downloaded. Check to see if the playback is "transcoding" or direct play How do i check this thanks.
thelangs 2 Posted February 28, 2017 Posted February 28, 2017 Start playback.. On the computer that runs the server, bring up the server dashboard.. You will see you movie selected and below the screenshot is the playback type.
Guest asrequested Posted February 28, 2017 Posted February 28, 2017 In the web app, go to the details page of the movie, scroll down and you'll see the file details. Can you post a shot of that?
mystic.bertie 23 Posted February 28, 2017 Posted February 28, 2017 here is the pic you asked for doofus The server dashboard shows the movie is trans-coding. What can be done here?
Guest asrequested Posted February 28, 2017 Posted February 28, 2017 Capture.PNG here is the pic you asked for doofus The server dashboard shows the movie is trans-coding. What can be done here? OK, there are multiple subs on that file. You should post the transcode log, and probably the server log for that time frame. I don't know if you like to try things, but the first thing I would try would be a quick remux with mkvtoolnix. Sometimes there is an error with container/splitting. If that didn't work, remux again and remove the subs. I'm assuming you can play it OK in other players? I think we need to nail this down, so maybe Luke and/or Babgvant can improve resilience. Let's get as much information as we can. If you dont want to experiment, maybe you can slice off a junk and share it? Then I can test it.
mystic.bertie 23 Posted February 28, 2017 Posted February 28, 2017 OK, there are multiple subs on that file. You should post the transcode log, and probably the server log for that time frame. I don't know if you like to try things, but the first thing I would try would be a quick remux with mkvtoolnix. Sometimes there is an error with container/splitting. If that didn't work, remux again and remove the subs. I'm assuming you can play it OK in other players? I think we need to nail this down, so maybe Luke and/or Babgvant can improve resilience. Let's get as much information as we can. If you dont want to experiment, maybe you can slice off a junk and share it? Then I can test it. Hi i dont mind experimenting but are you thinking this is a mkv file, its a blueray rip BDMV folder and 23gb, obviously its been reduced in size.
Guest asrequested Posted February 28, 2017 Posted February 28, 2017 Hi i dont mind experimenting but are you thinking this is a mkv file, its a blueray rip BDMV folder and 23gb, obviously its been reduced in size. Curious. It's h264. So it's folder rip. That may be the issue. We need to tag @@Luke in. I don't use folder rips. You'd be advised to remux to matroska. Luke, is there a known issue with folder rips?
Guest asrequested Posted February 28, 2017 Posted February 28, 2017 Can you post a shot of the contents of the folder where the movie is?
Luke 42240 Posted February 28, 2017 Posted February 28, 2017 No known issue but folder rips will transcode if the app does not have direct access to the folder.
mystic.bertie 23 Posted March 1, 2017 Posted March 1, 2017 Can you post a shot of the contents of the folder where the movie is? here you go, where do i find the transcoding log? I have a few bluray movies that are the same format and they behave the same way regarding skipping forward. Im going to try a full 44gb rip later tonight. From what i can see i have full access to these movie folders. I was not playing bluray folder rips for a long time so this is a new problem for me. For another reason i have installed emby server again today but it has not improved this situation.
mystic.bertie 23 Posted March 1, 2017 Posted March 1, 2017 (edited) I tried a Bluray folder rip which is 45gb and i get the same problem. Edited March 1, 2017 by mystic.bertie
mystic.bertie 23 Posted March 1, 2017 Posted March 1, 2017 What about a video file? a mkv file is direct play
Guest asrequested Posted March 1, 2017 Posted March 1, 2017 (edited) It's weird that the Blu-ray file is h264. We're gonna need those transcode logs.They are in the same place as the server logs. Click logs in the server, then right click the log you want and save. Then attach it here. Edited March 2, 2017 by Doofus
mentasm 43 Posted March 2, 2017 Posted March 2, 2017 I'm still finding this issue is affecting just about anything I watch. Movies and TV shows. It shows up mostly when I try and resume a video. It shows the search bar as the right location, but the actual video file plays from the beggining. I haven't changed anything in the config of my setup for quite some time so I am not sure whats going on or how to fix it. Skiping the file while playing it also causes the issue. Pretty much everything I am playing is from an online source and none of it was ripped by me.
Guest asrequested Posted March 2, 2017 Posted March 2, 2017 I'm still finding this issue is affecting just about anything I watch. Movies and TV shows. It shows up mostly when I try and resume a video. It shows the search bar as the right location, but the actual video file plays from the beggining. I haven't changed anything in the config of my setup for quite some time so I am not sure whats going on or how to fix it. Skiping the file while playing it also causes the issue. Pretty much everything I am playing is from an online source and none of it was ripped by me. Delete this folder and restart Theater. The LAV filters will re-download. C:\Users\YOU\AppData\Roaming\Emby-Theater\COMObjects\LAV
Guest asrequested Posted March 2, 2017 Posted March 2, 2017 (edited) OK, so I just folder ripped one of my discs, so I could try. Luke, ET won't direct play it. For me, it direct streamed. It's converting the dts to MP3. I wonder if this is the issue? I have this movie as an MKV with the same audio, and it plays directly. Could there be an issue with the ffmpeg probe? I've attached the server log. Look for time of around 20:32. I'm attaching the Theater log, also. Look for exotica. I should add that I was able to use the progress bar, though it was not smooth. Input #0, mpegts, from 'file:L:\Movies\EXOTICA\BDMV\STREAM\00011.m2ts': Duration: 01:43:14.24, start: 600.000000, bitrate: 24565 kb/s Program 1 Stream #0:0[0x1011]: Video: h264 (High) (HDMV / 0x564D4448), yuv420p(tv, bt709), 1920x1080 [SAR 1:1 DAR 16:9], 23.98 fps, 23.98 tbr, 90k tbn, 47.95 tbc Stream #0:1[0x1100]: Audio: dts (DTS-HD MA) ([134][0][0][0] / 0x0086), 48000 Hz, stereo, s32p (24 bit) Stream #0:2[0x1101]: Audio: dts (DTS-HD MA) ([134][0][0][0] / 0x0086), 48000 Hz, stereo, s32p (24 bit) Stream #0:3[0x1102]: Audio: ac3 (AC-3 / 0x332D4341), 48000 Hz, stereo, fltp, 192 kb/s Stream #0:4[0x1200]: Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090) Stream #0:5[0x1201]: Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090) Stream #0:6[0x1202]: Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090) Output #0, matroska, to 'S:\Transcode\transcoding-temp\2fb94a76476878a9c0c25c875dfc300e.mkv': Metadata: encoder : Lavf57.32.100 Stream #0:0: Video: h264 (H264 / 0x34363248), yuv420p, 1920x1080 [SAR 1:1 DAR 16:9], q=2-31, 23.98 fps, 23.98 tbr, 1k tbn, 90k tbc Stream #0:1: Audio: mp3 (libmp3lame) (U[0][0][0] / 0x0055), 48000 Hz, stereo, s32p (24 bit), 192 kb/s Metadata: encoder : Lavc57.34.100 libmp3lame Stream mapping: Stream #0:0 -> #0:0 (copy) Stream #0:1 -> #0:1 (dts (dca) -> mp3 (libmp3lame)) Edited March 2, 2017 by Doofus
Luke 42240 Posted March 2, 2017 Posted March 2, 2017 It will direct play if Theater has direct access to that L: folder.
Guest asrequested Posted March 2, 2017 Posted March 2, 2017 (edited) It will direct play if Theater has direct access to that L: folder. My drives and folders are on the server machine. I can't give it more direct access. Wait! I missed that. So I'm running Theater on my HTPC over my network, which is directly connected to the same switch as the server. Edited March 2, 2017 by Doofus
