theAkran 1 Posted February 19, 2017 Posted February 19, 2017 Previously, everything was working perfectly but my SchedulesDirect subscription ran out. When I got it back, I could no longer get guide data to show up in Emby, though it works fine in NPVR. I believe I might have a corrupt database file, but not sure which one. I've attached a log file with some information edited for security/privacy reasons. emby.server.log
Luke 42237 Posted February 19, 2017 Posted February 19, 2017 Hi, yes Corrupt: database disk image is malformed You will need to locate your library.db file and delete that, then startup the server and run a library scan and guide refresh. Please note, this file also contains watch data, so you might consider renaming it instead of deleting it. Let us know if this helps. thanks !
theAkran 1 Posted February 19, 2017 Author Posted February 19, 2017 Thanks for the quick response. Is there a way to replace the watch data once I've regenerated the db file?
Luke 42237 Posted February 20, 2017 Posted February 20, 2017 hi @@theAkran It might prove difficult due to the corrupt library database, but you can try. We have two migration options documented here: https://emby.media/community/index.php?/topic/10427-how-to-migrate-emby-server If you go with the first option, you would have to temporarily put the old library db back in place. With the second option, you can use any standalone Sqlite tool such as SqliteBrowser.
