isamudaison 12 Posted February 17, 2017 Posted February 17, 2017 So I've 'resolved' my emby hanging by removing very large paths that couldn't be resolved, but now I've got a problem with mono-sgen pegging my CPU. Attached is a log, and it's obvious there's something very wrong with the library monitoring (notice the massive 'type change detected' entries). Here's the process that's hogging all my CPU: /usr/bin/mono-sgen --optimize=all /usr/lib/emby-server/bin/MediaBrowser/Server/Mono.exe -programdata /var/lib/emby-server -ffmpeg /usr/bin/ffmpeg -ffprobe /usr/bin/ffprobe -restartpath /usr/lib/emby-server/restart.sh emby_debug.txt.tar.gz
Luke 42245 Posted February 17, 2017 Posted February 17, 2017 Do you see the same behavior if you disable the realtime monitor?
isamudaison 12 Posted February 18, 2017 Author Posted February 18, 2017 Do you see the same behavior if you disable the realtime monitor? I don't seem to have that option under 'library->advanced' (or anywhere, really...)
mastrmind11 722 Posted February 18, 2017 Posted February 18, 2017 I don't seem to have that option under 'library->advanced' (or anywhere, really...) it's per library, so click on each and disable it.
isamudaison 12 Posted February 18, 2017 Author Posted February 18, 2017 I see some oddness with realtime monitoring... I copied a file over to one of the library locations and pulled up a system monitor to see what happens. After a minute or so, the 'mono-sgen' process kicks up CPU usage quite a bit, and then it started to settle down, and then it kicked up even more, and started to settle down, and then it kicked up even more... it did this for a few minutes, but then finally settled back down to zero. I could see this happening and never recovering as being a real possibility.
isamudaison 12 Posted February 18, 2017 Author Posted February 18, 2017 it's per library, so click on each and disable it. That makes sense, I've disabled them all and set the media library scan to hourly, I'll keep an eye on it.
isamudaison 12 Posted February 18, 2017 Author Posted February 18, 2017 No bueno... I've added back my home video category and as it was scraping, the mono process spiked CPU and emby hung... I'm guessing there needs to be a gdb dump to figure this out?
isamudaison 12 Posted February 22, 2017 Author Posted February 22, 2017 Well this is fun... every time I attempt to attach to the emby process, gdb throws an error and then emby hangs. Ever seen this error from gdb? "../sysdeps/unix/sysv/linux/x86_64/pthread_cond_wait.S: No such file or directory"?
isamudaison 12 Posted February 23, 2017 Author Posted February 23, 2017 (edited) Here's as much as I could get (emby is in the hung state with gdb attached, I performed a bt full (see attached) I think the real problem is there are over 2000 threads running... *Edit: added 'full' thread dump gdb.txt Edited February 23, 2017 by isamudaison
isamudaison 12 Posted February 23, 2017 Author Posted February 23, 2017 Possibly related: https://bugzilla.xamarin.com/show_bug.cgi?id=42665 Seems like maybe I'll have to wait until Mono releases a new stable (I'm assuming Emby has done some tweaking to their mono usage in the past couple versions to add all this 'speed' ?)
isamudaison 12 Posted February 23, 2017 Author Posted February 23, 2017 Wow, The mono peoples' ears must've been burning They've just pushed 4.8 to stable. I've upgraded and will monitor any improvements.
Luke 42245 Posted February 23, 2017 Posted February 23, 2017 Wow, wasn't expecting that just yet. Thanks for the info.
isamudaison 12 Posted February 24, 2017 Author Posted February 24, 2017 Just a quick update: so far, so good. No apparent freezing/crashing, and I've also enabled real-time monitoring. I'll give it another day before I call it 'solved' Until then I'd highly recommend updating to the new mono to anyone having library scanning issues
Luke 42245 Posted February 24, 2017 Posted February 24, 2017 Very interesting, thanks for the info. For us we're not likely to put 4.8 into our stable branch yet but we'll probably start looking at it in beta soon. Thanks.
isamudaison 12 Posted February 26, 2017 Author Posted February 26, 2017 Let's call this solved... It's been Rock solid after the upgrade.
