Search not working and library only displays to movies with letter M
Clinically_Sane
Hi
I have an LG Smart TV model:55UB830T-TG.
Emby Server Version: 3.2.1.0
The built in DLNA client no longer allows me to search any library and when viewing my movies library I can scroll till movies starting with 'M' using the sidebar. Scrolling down using the wheel results in "Error Loading Files" and have to exit and re-enter.
That wouldn't be a problem if I could search however clicking in the search box does nothing.
I'm not certain if an update to the television software has caused this or if there is something I can do on emby's side to  make it work. It has worked fine in the past. Normally I stay in the Recents folder so it's been a while since I used the search feature or tried to find a movie in the Movies folder.
Thanks
Jason
