Parki79 0 Posted February 16, 2017 Posted February 16, 2017 IS there any way to sort by alphabetical order?
ebr 16335 Posted February 16, 2017 Posted February 16, 2017 If you sort by "Channel Number" that is actually sorting by the "Sort Title" as defined in the metadata for each channel. So, you could remove the numbers from that field.
