tobedeleted 4 Posted February 16, 2017 Posted February 16, 2017 When I try to sync artists like "R.E.M." to my Android phone, every song gets in its own artist folder, named "R.E.M" (without dot), "R.E.M." (correct), "R.E.M. (1)" and so on. For every single song! Any remedy?? (Server 3.2.1.0 on Linux, Android client 2.8.67 (should be the most recent versions).
Luke 42243 Posted February 16, 2017 Posted February 16, 2017 hi @@Larx, so are you saying it never completes the sync but just keeps going again and again creating new folders?
tobedeleted 4 Posted February 16, 2017 Author Posted February 16, 2017 At the time of the first post I had thought of a merely cosmetical problem. But as during the rest of today Emby tried syncing the songs of the dot-ending artists over and over again, creating dozens of numbered artist folders for them and never finishing, yes, that's exactly the problem!
Luke 42243 Posted February 17, 2017 Posted February 17, 2017 @@Larx, have you configured a custom sync path, or is it the default?
tobedeleted 4 Posted February 17, 2017 Author Posted February 17, 2017 On the Android device? Yes, I'm syncing to the external SD card, using the document provider. content://com.android.externalstorage.documents/tree/1234-5678%3A The 1234-5678 is the UID of the card, I don't know what %3A is (maybe '/'). I selected the root of the SD card, as the sync process itself always creates another subfolder with the name of the media server (which is useless for me, as I only use one server).
tobedeleted 4 Posted February 17, 2017 Author Posted February 17, 2017 FYI, 2.8.68. still has the problem.
Luke 42243 Posted February 24, 2017 Posted February 24, 2017 @@Larx please try the latest open beta version. thanks !
tobedeleted 4 Posted February 25, 2017 Author Posted February 25, 2017 I'm signed in to the beta programm, however, as I don't use Google Play (MicroG + Yalp Store instead), I don't really know if I have the current beta. If com_mb_android-200008732.apk is the most recent version, this one still doesn't work.
tobedeleted 4 Posted February 27, 2017 Author Posted February 27, 2017 Just for the record. 2.8.76 no change.
tobedeleted 4 Posted March 4, 2017 Author Posted March 4, 2017 2.8.77 and also phone upgraded from MM to N, all the same :-(
tobedeleted 4 Posted March 13, 2017 Author Posted March 13, 2017 Is there any progress with this issue? The problem is not only the multiple folders when artists end with ".", but also that the synchronisation always gets stuck. Songs of these artists simple seem to get synced over and over again.
tobedeleted 4 Posted May 15, 2017 Author Posted May 15, 2017 Well, any progress??! I still cannot sync anything ending with a dot :-( .
Luke 42243 Posted June 16, 2017 Posted June 16, 2017 @@Larx, please try 2.9.11 on the open beta: https://emby.media/community/index.php?/topic/24350-android-open-beta-testing/ I am not able to reproduce this anymore. Please let me know if this helps. Thanks !
tobedeleted 4 Posted June 20, 2017 Author Posted June 20, 2017 (edited) @@Larx, please try 2.9.11 on the open beta: https://emby.media/community/index.php?/topic/24350-android-open-beta-testing/ I am not able to reproduce this anymore. Please let me know if this helps. Thanks ! Sorry, still does not work.... 2.9.12 installed. Edited June 20, 2017 by Larx
Luke 42243 Posted June 20, 2017 Posted June 20, 2017 Ok I'll keep testing, thanks. It's odd because I'm able to sync the very same artist with no problem.
tobedeleted 4 Posted June 24, 2017 Author Posted June 24, 2017 Why not simply convert those problematic characters to an underscore or something like that? Lots of desktop software dealing with music files on different filesystems do that. Looks a bit awkward, but works. Frankly, this problem has not found a clean solution for months, so even something quick & dirty would be welcome ;-) . 1
tobedeleted 4 Posted July 8, 2017 Author Posted July 8, 2017 Is there any hope that this problem will be solved at some point???????
Luke 42243 Posted July 21, 2017 Posted July 21, 2017 @@Larx what version of the app are you running now?
