ucantcme69 2 Posted February 16, 2017 Posted February 16, 2017 (edited) Hello folks. I just got a HDHomeRun Prime and setup everything. After a few struggles I seem to have almost everything worked out besides a couple issues. The first issue is that the guide isn't pulling any info for my HD channels. It appears to be pulling the SD channels just fine but all of the HD channels are missing info. Secondly for some reason two ESPN channels appear to be listing at the top of my guide for no reason. Lastly it seems to take an incredibly long time to refresh guide data. Any hints? I am using schedules direct to pull the guide in. I tried out some xml stuff first but there was way to many missing channel information and it became a hassle. If I could just get the SD channels to replicate to the HD channels i'd be pretty close to being in business. Hope this is the correct log if it's needed as well server-63622540800.txt Edited February 16, 2017 by ucantcme69
maegibbons 1287 Posted February 16, 2017 Posted February 16, 2017 (edited) Hi Have you tried manually mapping the HD channels? Go to the "guide providers" setting in live tv setup and hit three dot menu on right and choose Map Channels. With regard to odd ordering, In the guide itself hit the 3 dot menu at the top of the channel number list and deselect "Place favourite channels at beginning". You may NOT have favorited these channels - there is a bug somewhere. BTW do not try mapping two channels to the same EPG data. I.e HD and SD to SAME SD source channel. If you do you will only get data for one channel shown. There is a bug/ommision in the routines at the moment that stop you from doing this which the devs know about. Krs Mark Edited February 16, 2017 by maegibbons
ucantcme69 2 Posted February 16, 2017 Author Posted February 16, 2017 Thank you. The favorites channels were the reason for those jumping to the top of the list. I have that part sorted out. That being said I still cannot get the HD channels to display any guide information. The weird thing is it did pull it through last night and then I went to bed and this morning its back to missing again. It already looks to be correctly mapped as far as I can tell if I go to manually map it for example ESPN HD is already mapped to ESPN HD. Any thoughts?
Luke 42243 Posted February 16, 2017 Posted February 16, 2017 When mapping two channels to the same guide channel there is an issue with one of them displaying empty and you can track that issue here: https://emby.media/community/index.php?/topic/44799-bug-guide-listings/&do=findComment&comment=419519 As far as data loading, can you please describe that a little bit more? Your supplied log does not contain anything related to that. thanks.
ucantcme69 2 Posted February 16, 2017 Author Posted February 16, 2017 (edited) Data load times doesn't seem to be an issue now as far as I can tell it looks like its fairly reasonable. My channels aren't mapped to the same selection. As a matter of fact I went into the hdhomerun interface and disabled the SD channels that also had HD channels. I'll use ESPN for instance. it will continue to grab the guide information and then it'll loose its guide information later. It happens to a few other channels as well. I wiped the live tv xml file and let it repopulate and this continues to happen. I even switched back to the xml option and got the majority of it working. It looks like im really only down to the guide information staying put after it grabs it now to display. I will attach a new screen to show you what im struggling with now. I went through and mapped every single channel that wasnt already mapped. I've seen each one of them pull guide information and display it and then it'll start doing this again: Edited February 16, 2017 by ucantcme69
ucantcme69 2 Posted February 16, 2017 Author Posted February 16, 2017 I just went in and deleted the channel manually from the live tv xml file and reran the task. It pulled the guide info. When I went back to the home page in emby and then back into the guide for live tv the guide info for that channel is now blank again. Pretty frustrating as thats the only thing I have left to get taken care of.
ucantcme69 2 Posted February 17, 2017 Author Posted February 17, 2017 (edited) Any other information or logs I can supply? It makes no sense that if I delete the entries from the livetv.xml file it will repopulate the correct information but then disappear the next time I check the guide. Very willing to supply what ever I can. All the channels are correctly matched. It's driving me crazy. I added a zip of my log file as it was slightly to big. Thanks server-63622800000.zip Edited February 17, 2017 by ucantcme69
Luke 42243 Posted February 17, 2017 Posted February 17, 2017 hi @@ucantcme69, are you using schedules direct or xml tv? Try deleting the one you're not using, just in case there might be an issue there. then run the guide refresh. thanks.
ucantcme69 2 Posted February 17, 2017 Author Posted February 17, 2017 I've tried them both. I only have one going at a time. The same issue happens with both. Each time I delete the contents of the xml file to repopulate. When it repopulates all of the guide content is there. When I navigate away from the guide page and come back it results in the last screen shot I uploaded and a bunch of channels loose guide information.
Luke 42243 Posted February 17, 2017 Posted February 17, 2017 Ok, can you switch to schedules direct and then provide a log from that? thanks.
ucantcme69 2 Posted February 17, 2017 Author Posted February 17, 2017 Hello, Sure thing. I switched it back over to schedules direct and have the server log attached below. Thanks server-63622886400.txt
ucantcme69 2 Posted February 18, 2017 Author Posted February 18, 2017 Just noticed that might be small so ill post the last 2 that I see in the logs folder server-63622713600.txt server-63622886400.txt
ucantcme69 2 Posted February 18, 2017 Author Posted February 18, 2017 Also after switching back to schedule direct the channels are mapped properly and briefly came up in the guide but navigating back to it now looks like everything below the last entry on the picture is missing again:
ucantcme69 2 Posted February 18, 2017 Author Posted February 18, 2017 I just noticed that any channels without guide data won't play either. Fails on a xbox one and roku that I've tested on. Any channels with guide data play as expected. Super weird
Luke 42243 Posted February 18, 2017 Posted February 18, 2017 Can you provide the server (and ffmpeg log) from the playback attempt? thanks.
ucantcme69 2 Posted February 18, 2017 Author Posted February 18, 2017 I believe these might be what you're looking for? If not I'm happy to grab anything you need. record-transcode-d94568ce-6397-49b6-a552-3af14df8da67.txt server-63622886400.txt ffmpeg-remux-2a49ef02-6648-4bf2-ac72-515d5cce0e47.txt ffmpeg-remux-c54a0c56-da36-431c-8e4e-3d237e8e7684.txt ffmpeg-transcode-998bcb64-6c65-42c0-9ca1-7897f2adc9d3.txt ffmpeg-transcode-5869aae0-820e-408a-87a5-e076d86ffba4.txt ffmpeg-transcode-c43fb5fa-7133-4082-87e6-8f87f6492749.txt
Luke 42243 Posted February 18, 2017 Posted February 18, 2017 can you put this url in a browser and provide the result? http://192.168.1.26/lineup.json Also, can you provide me the xml file you were using before? I will test your setup exactly. thanks.
ucantcme69 2 Posted February 18, 2017 Author Posted February 18, 2017 Attached is the text I saved from the json test and the current livetv.xml file ran with schedules direct. Works great when the guide data is available and my channels play well on all of my devices. Without the guide data its dead in the water. lineup.json.txt livetv.xml
maegibbons 1287 Posted February 18, 2017 Posted February 18, 2017 (edited) Hi That livetv.xml file contains no channel data. it looks like more of a config file for an HDhomerun app EPG than an xmltv data file. How do you obtain the xmltv file from SD? You should be using something like "tv_grab_sd_json" to create a local xmltv file I use xmltv data from SD quite succesfully for m3u channels HOWEVER i use the built in json grabber for for my HDhomerun channels. Krs Mark Edited February 18, 2017 by maegibbons
ucantcme69 2 Posted February 18, 2017 Author Posted February 18, 2017 This is the one I was using for the xmltv option. IS there something more to setup in order to use schedules direct? I thought it was literally sign into my account and select the options under the guide section in emby, run the task and that was that. xmltv.xml
maegibbons 1287 Posted February 18, 2017 Posted February 18, 2017 For inbuilt SD json parser it should just be configure and run. SD and hdhomerun works ok for me in the uk. Krs Mark
maegibbons 1287 Posted February 18, 2017 Posted February 18, 2017 Hi The xmltv file is correctly formatted When using xmltv did you map the channels manually? Krs Mark
Luke 42243 Posted February 18, 2017 Posted February 18, 2017 What is a specific example of a channel i should look at? because what I am seeing is what you are describing - guide data disappears for some channels during the guide refresh, but by the end of the refresh everything is restored as it was before. I can certainly look into why that is happening but that doesn't seem like a catastrophic issue to me. I do have many blank channels in the guide but i haven't yet looked at whether this is due to channel mapping or some kind of problem.
Luke 42243 Posted February 18, 2017 Posted February 18, 2017 OK, after further investigation, this is due to mapping two channels to the same EPG data, causing one of them to be empty. This has already been recently reported here: https://emby.media/community/index.php?/topic/44799-bug-guide-listings So you can monitor the issue in that topic. thanks !
ucantcme69 2 Posted February 19, 2017 Author Posted February 19, 2017 I don't understand how thats the case. I've blocked all of the SD channels and even then they were mapped to their SD channel counter part and the HD versions were marked to their HD channel.So are you saying theirs no way to actually fix this? That link doesnt even look like its the same issue as mine. That one describes a guy with two devices trying to map channels. This is just one device trying to map each channel to its correct xml data. I've manually went through and mapped each channel myself and it still doesnt pull through. the ABCHD channel as well as ESPN and ESPN2 would be good tests but I fail to see how this is my issue. This could just be me not really understanding what you're saying and I apologize if thats the case I did see you posted that that would be resolved soon so if that happens I can give it a try again when the next update happens. Any chance theirs a estimated time frame for that? Thank you
