Old_School 1 Posted February 15, 2017 Posted February 15, 2017 Hi am new to emby i have install the emby server on my computer but can not connect to it from my fire tv 4k
Luke 42244 Posted February 16, 2017 Posted February 16, 2017 Hi there old_school, we're sorry to hear about your issue. Can you describe it a little bit more? is Emby Server running when you try to do this? What happens in the Fire TV Emby app? Does it give you an error message? Thanks ! 1
Old_School 1 Posted February 16, 2017 Author Posted February 16, 2017 (edited) Hi yes emby server is running am getting error connecting to server on the app Edit : don't know if this is cause i did not allowed it on public network on my windows firewall when ask by windows firewall Edited February 16, 2017 by Old_School
Luke 42244 Posted February 16, 2017 Posted February 16, 2017 Thanks @@Old_School. Can you tell us what the error says? How did you try to connect to the server, did you manually enter the ip address? Thanks ! 1
Solution Old_School 1 Posted February 16, 2017 Author Solution Posted February 16, 2017 (edited) Hi i got it working now it was being block by windows firewall on public networks Edit : got it working on the fire tv app and kodi for fire tv Edited February 16, 2017 by Old_School 1
ebr 16337 Posted February 16, 2017 Posted February 16, 2017 Glad you got this working but, if you are dealing with a normal in-home network, I would ensure that it is setup as a Private network as most things will be blocked by default on a public one. 1
Old_School 1 Posted February 16, 2017 Author Posted February 16, 2017 Hi ebr thanks i just check and my in-home network was set to public don't know why but i have set it back to private network
