WSJ 3 Posted February 15, 2017 Posted February 15, 2017 After the last update the plugins covert art 4.0.23.0 could not work reinstall several times and remains the same I block the emby server and I get an error in windows I need help
Luke 42197 Posted February 15, 2017 Posted February 15, 2017 Hi @@WSJ, sorry to hear about your issue. Can you translate that dialog box for us? thanks ! 1
WSJ 3 Posted February 19, 2017 Author Posted February 19, 2017 ok, la traduccion es "windows esta enviado informacion a microsoft que puede ayuda a solucion del problema" el problema es con el plugins "covert art" luego de la ultima actualizacion lo he instalado cantidad de veces y sigue igual .. me bloquea emby server , no sirve "covert Art" 1
