Smart Playlist for Background
dranderson402
I'm not sure if this is a kodi for emby, emby, spmc or skin problem. I used to be able to select the playlist as the source for the background images in my titan skin menu items. This has recently stopped and I think it happened after both emby and kodi for emby both updated to thier recent stable versions.
I had made a smart playlist for unwatched tv shows. I then used that as an action for a menu item on my home screen. It wasn't instant, I had to wait a little while but I was then able to set the background and thumbnail to use the unwatched tv shows playlist as the source for the background. However, since the last updates I no longer have any background images for the menu item and also there is no longer an option to choose the playlist for the background.
Like I said, I don't know if the problem is the kodi for emby plugin, emby itself, spmc or titan but only emby and the kodi for emby plugin have recently updated. It worked prior to those updates.
dranderson402
Ok, I'm going with a skin problem which made the most sense. I installed the beta version of titan and it's working properly now.
Thanks for reporting back.
Guest
