Spaceboy 2573 Posted February 14, 2017 Posted February 14, 2017 Hi, I wonder if any mediaportal users can give any advice. i get my epg through the xmltv plugin and its downloaded fresh daily so its always up to date. despite having the option ticked in the xmltv plugin mediaportal does not refresh the epg database so after a few weeks i will start to see "To Be Announced" appearing lots in the guide. so far my solution ha been to reset the epg databse every month or so, it gets refreshed this way in a few minutes. But i want to fix it. Does anyone else get their epg using xmltv and do you have this problem? Am i just going to get told to use a newer version of MP if i post this on their forum? ta
pünktchen 1410 Posted February 14, 2017 Posted February 14, 2017 What options exactly do you have ticked? I'm using xmltv since years without any problem. Btw. they wont tell you to install a newer version, because the general epg handling and also the xmltv plugin hasn't changed since many many many years [emoji6]
Spaceboy 2573 Posted February 14, 2017 Author Posted February 14, 2017 (edited) What options exactly do you have ticked? I'm using xmltv since years without any problem. Btw. they wont tell you to install a newer version, because the general epg handling and also the xmltv plugin hasn't changed since many many many years [emoji6] here you go: cheers for taking a look i did also take a look at the possibility of using schedules direct in mp as well but the older xml data isnt available for non US users Edited February 14, 2017 by Spaceboy
pünktchen 1410 Posted February 15, 2017 Posted February 15, 2017 Do you download your xmltv file with an external program or with the remote section of the plugin? Have you noticed if the last import time changes every day? Do you have disabled DVB EPG?
