alexwilson 3 Posted February 14, 2017 Posted February 14, 2017 The system menu used to be considered "to the right" of the search icon. Navigating by directional keys to the top and then right would go from collections to search to the system menu. Now the system menu appears to be a UI orphan, and I don't think it can be reached by arrow keys. Esc does bring it up, so it's not a huge deal, but it does seem weird you need a mouse if you want to navigate to it -- finding Esc in the dark is a little harder on some keyboards/remotes than the d-pad. Not sure if it got orphaned by accident or design, but please consider this a vote to (re-)adopt.
Luke 42243 Posted February 14, 2017 Posted February 14, 2017 Hi, yes a couple people have reported this but i haven't been able to reproduce. what is your windows resolution and dpi setting?
alexwilson 3 Posted February 14, 2017 Author Posted February 14, 2017 (edited) 1920x1080, 150% (on the "Change the size of text, apps, and other items" slider) Edited February 14, 2017 by alexwilson
