shavid0610 0 Posted January 14, 2018 Author Posted January 14, 2018 Hi I did this customisation initially before Media Browser became Emby and I'm not sure if it still held when it became Emby for WMC. The instructions I followed initially at the top of this post refer to C:\Users\[Username]\AppData\Roaming\MediaBrowser-Server but this location no longer exists. Is there a different method to have classification icons show in Emby for WMC than there were for Media Browser Classic? Thanks so much for your help
Happy2Play 9811 Posted January 14, 2018 Posted January 14, 2018 Hi I did this customisation initially before Media Browser became Emby and I'm not sure if it still held when it became Emby for WMC. The instructions I followed initially at the top of this post refer to C:\Users\[Username]\AppData\Roaming\MediaBrowser-Server but this location no longer exists. Is there a different method to have classification icons show in Emby for WMC than there were for Media Browser Classic? Thanks so much for your help Does C:\Users\[Username]\AppData\Roaming\Emby-Server?
shavid0610 0 Posted January 14, 2018 Author Posted January 14, 2018 Does C:\Users\[Username]\AppData\Roaming\Emby-Server? Looked there but the only folders are programdata and system. There is no imagesbyname folder anywhere to put the mediainfo folder into to then put the classification icons into
Happy2Play 9811 Posted January 14, 2018 Posted January 14, 2018 Right IBN was replaced by metadata folder at least a year ago. I believe you just put your mediainfo folder in programdata\metadata.
shavid0610 0 Posted January 14, 2018 Author Posted January 14, 2018 Ah thank you I have put my icons in there and it is working. Thank you so much
shavid0610 0 Posted January 15, 2018 Author Posted January 15, 2018 Hi again Not sure what has happened but this feature was working yesterday (for most titles anyway) and today there are no icons showing at all on any titles in Emby for WMC. Some titles have a Text image showing the classification (only PG and G rated ones) but most have none. I have saved all my icon images to C:\Users\HTPC\AppData\Roaming\Emby-Server\programdata\metadata\mediaInfo\All and have the files named in the following fashion rated_au_g.png rated_movie_au_g.png rated_au_m.png etc Any help to get the icons back would be appreciated Thank You Sharon
Luke 42237 Posted January 15, 2018 Posted January 15, 2018 Can you discuss a specific example? Thanks.
shavid0610 0 Posted January 15, 2018 Author Posted January 15, 2018 Can you discuss a specific example? Thanks. OK, some of them have reappeared today, some are still missing and some are showing the text icon. The classifications used to appear on the right hand side of the stars as per capture 3 on every title. Today I have some blank like capture 1, some with text classifications like capture 2 and some with the correct icons like capture 3. There doesn't appear to be any difference between old or new media titles, some old ones have the icon, some don't. Most titles have nothing showing
Luke 42237 Posted January 15, 2018 Posted January 15, 2018 have you checked the metadata in emby for these titles? i bet it's the same issue as your other thread. you probably have the rating in an xml tag that we're not even looking at.
ebr 16332 Posted January 15, 2018 Posted January 15, 2018 Or it has invalid content in the one we are...
shavid0610 0 Posted January 15, 2018 Author Posted January 15, 2018 OK, where does Emby look in the xml doc for the rating. I have been through this issue before and I know there are 3 locations in the xml doc that hold the rating.
Luke 42237 Posted January 15, 2018 Posted January 15, 2018 There's just two now: case "ContentRating": case "MPAARating":
shavid0610 0 Posted January 15, 2018 Author Posted January 15, 2018 I tried to load text files of xml data for the 3 movies I used as examples but it won't let me. The xml for all 3 has the correct rating in 3 separate locations 21 & Over has <MPAARating>MA15+</MPAARating> near the top of the document and <ContentRating>MA15+</ContentRating> <certification>MA15+</certification> nearer the bottom 17 Again as <MPAARating>PG</MPAARating> near the top <ContentRating>PG</ContentRating> <certification>PG</certification> nearer the bottom Zombieland has <ContentRating>MA15+</ContentRating> <MPAARating>MA15+</MPAARating> near the top <certification>MA15+</certification> nearer the bottom As Zombieland is the one that is working correctly should the content rating be near the top? But should this matter as long as the information is there? And why were 90% of the titles showing the icon correctly and today only 10% are and the metadata hasn't changed in that time?
Luke 42237 Posted January 15, 2018 Posted January 15, 2018 Here is part of the problem. Xml support as a whole is now legacy and the xml plugin you're relying on is community contributed. There might be some questions here that we may not have answers to. I would strongly suggest removing the plugin and switching to our default nfo format that we've been using now for the last several years. However, if you want to stay with xml, then the important thing to look at is the metadata in the Emby web interface, not your xml files. That will tell you if Emby has imported the value from your xml, or not, and you can always change it using the editor functions in the web interface.
shavid0610 0 Posted January 15, 2018 Author Posted January 15, 2018 Can I edit an nfo file if the Australian rating doesn't fetch correctly?
ebr 16332 Posted January 15, 2018 Posted January 15, 2018 Can I edit an nfo file if the Australian rating doesn't fetch correctly? Hi. You can always edit the metadata using the Emby metadata manager.
