Koleckai Silvestri 1154 Posted February 4, 2014 Posted February 4, 2014 Does this plugin set the sort title to the release year for automatic sorting?
Solution ebr 16343 Posted February 4, 2014 Solution Posted February 4, 2014 No because it uses links to the actual movies. It doesn't alter their metadata in any way. 1
Koleckai Silvestri 1154 Posted February 4, 2014 Author Posted February 4, 2014 Thanks. Have been using that for manual collection sorting.
ebr 16343 Posted February 4, 2014 Posted February 4, 2014 MBC will allow you to sort your box sets by year so you don't have to alter their normal sort order. Can you not do this in the clients you are using?
Koleckai Silvestri 1154 Posted February 4, 2014 Author Posted February 4, 2014 Using MBT, it only has a global sort order as far as I can tell. I want this to be by title. This has to be worked around for collections. Had to remove the trailers addon because i couldnt sort them by date added while movies were sorted by title. Don't want to force people to change the sort order to get things in proper lists. Not a big deal, can continue using the manual method of creating box sets as needed.
ebr 16343 Posted February 4, 2014 Posted February 4, 2014 Okay, yeah, the sorting options just need to be improved in MBT. I'm sure it will get there.
