Vagnavs 0 Posted February 12, 2017 Posted February 12, 2017 (edited) Hello, I am trying to get the server to work with my Yamaha RX-V679BL 7.2-Channel MusicCast AV Receiver. It will detect it in the server software. But it will not show up when I use the Yamaha app on my phone. I tried using a profile someone made up for Yamaha.. But still doesn't work.. Any help would be great! I'm trying to find some reliable software whether it's free or paid. Thanks for your time, Brian Edited February 12, 2017 by Vagnavs
Vagnavs 0 Posted February 12, 2017 Author Posted February 12, 2017 (edited) where do you get the yamaha app? https://play.google.com/store/apps/details?id=com.yamaha.av.avcontroller&hl=en I have tried universal media server and it works sporadically. So was hope in this server software would work better Edited February 12, 2017 by Vagnavs
Luke 42239 Posted February 12, 2017 Posted February 12, 2017 yea I'm sure there's a trivial answer, the main issue is we don't have a yamaha receiver in house for testing. I was hoping I could test the app myself without a yamaha receiver but it doesn't look like that's possible. Have you tried just giving the app a minute? there are mulitple detection methods so depending on what the yamaha supports it could be instantaneous or it could be up to a minute later. thanks.
Vagnavs 0 Posted February 13, 2017 Author Posted February 13, 2017 After some tweaking. I got it to work. Thank you for the feedback. I'll see if the premiere membership is something I can use. I usually just do music streaming.
Vagnavs 0 Posted February 13, 2017 Author Posted February 13, 2017 Thanks. How did you get it to work? I think I got to work by using my username under DLNA, Instead of default user..
Vagnavs 0 Posted February 13, 2017 Author Posted February 13, 2017 How many users have you added? Just one
