Luke 42197 Posted February 16, 2017 Posted February 16, 2017 @@kodibart, yes change the content type of walking dead to inherit. Let us know if this helps. thanks !
CharleyVarrick 284 Posted February 16, 2017 Posted February 16, 2017 Anyone knows how he might have managed to do this, that is set seasons within a tv show to specific content (tv)?
Happy2Play 9802 Posted February 16, 2017 Posted February 16, 2017 Anyone knows how he might have managed to do this, that is set seasons within a tv show to specific content (tv)? Well personally this option is broke as this setting is required for Complex folder structure. It use to appear on all Content types, so It would had to happen awhile ago or kodibart is using Unset/Mixed library content type.
Luke 42197 Posted February 16, 2017 Posted February 16, 2017 also try deleting tvshow.nfo from the season folder, then run a library scan.
Happy2Play 9802 Posted February 16, 2017 Posted February 16, 2017 also try deleting tvshow.nfo from the season folder, then run a library scan. Deleting the nfo will not remove the information already written to system.xml, unless something has changed.
Luke 42197 Posted February 16, 2017 Posted February 16, 2017 Correct but that file might be causing mis-detection in the season folder. Probably but worth trying. The important thing is probably my previous suggestion: yes change the content type of walking dead to inherit. Let us know if this helps. thanks !
kodibart 0 Posted February 17, 2017 Author Posted February 17, 2017 Guys, everything seems to be OK now. First I deleted every tvshow. nfo file in every season folder (7 in total) then in Metadata Manager I switch The Walking Dead to Inherit and did a rescan of my library. Now I have averything I want like episode information pictures of the characters etc. Thank you all
