ginjaninja 605 Posted February 12, 2017 Posted February 12, 2017 Server 3.2.1 Client downloaded yesterday. Im connecting remotely accross internet using emby connect for first time. Pin registration for connect for tv works. At 'select a server' screen icon shows a local ip (192.168.x.x) . Message is server is unavailable Manual server entry also is unsuccesful in android tv emby client on both http and https ports. My phone is able to connect fine using android client. Chrome is able to connect fine. Sent from my GT-I9505 using Tapatalk
ebr 16337 Posted February 12, 2017 Posted February 12, 2017 There should be a "Send Log" button on the screen after the attempt to connect fails. Please press it and then let me know exactly when that was. Thanks.
ginjaninja 605 Posted February 13, 2017 Author Posted February 13, 2017 Ok will try next time..might be a few weeks before im back again..
1ntroduc3 4 Posted February 13, 2017 Posted February 13, 2017 I had exactly the same. What did the trick for me was adding 8096 (or the other port you're using for emby) to the firewall as open/allow or however you call it on the server where your emby server is running on. Even though all other systems work, android TV didnt work for me. After adding to firewall, it worked! 1
Luke 42244 Posted February 13, 2017 Posted February 13, 2017 I had exactly the same. What did the trick for me was adding 8096 (or the other port you're using for emby) to the firewall as open/allow or however you call it on the server where your emby server is running on. Even though all other systems work, android TV didnt work for me. After adding to firewall, it worked! thanks for the feedback !
