kanipek 230 Posted February 11, 2017 Posted February 11, 2017 Here is the situation: I am using HDHR Connect, HDHR Prime and HDHR Prime with CableCard I have several channels that have this issue - I have channels that appear different between Connect and Prime CableCard for instance Connect channel 5.2 (WEWSDT2) appears as 153 on the Prime CableCard. The problem - When I map them both to the correct listings the program guide shows no data for one of them. So I can't map the same guide listing to 2 different channels. So my question(s): Should I be able to do this? If yes what am I doing wrong? If this can't be done would it be possible to create a "copy listings" feature to allow it? Is there a way to "unmap" a channel after it has been mapped? Can't seem to find a way - there is no blank/empty listing in the channel map list. For the moment I am mapping the channels on the Prime CableCard to a different channel like Barker or VOD. I am attaching a log. Thanks for reading and any help! server-63622415357.txt
kanipek 230 Posted February 13, 2017 Author Posted February 13, 2017 If this is in the wrong area please move it.
maegibbons 1287 Posted February 13, 2017 Posted February 13, 2017 (edited) Hi Unfortunately, at the moment, you cannot map two channels to the same EPG data. As you have found, you will only get data filled for one Channel. I have asked for this to be fixed but not happening yet. To delete mappings you need to find the livetv.xml file in emby-server/config and delete the mappings manually.using an editor. Krs Mark Edited February 13, 2017 by maegibbons 1
Luke 42243 Posted February 13, 2017 Posted February 13, 2017 @@maegibbons can you provide a link to your originally reported issue? thanks !
maegibbons 1287 Posted February 13, 2017 Posted February 13, 2017 Hi @@Luke In this thread: https://emby.media/community/index.php?/topic/43594-live-tv-issues/&do=findComment&comment=409230 And mentioned by a couple of other users in the same thread - one that I had previously quoted. I have mentioned it elsewhere too but cannot track that thread at the moment. Krs Mark
Luke 42243 Posted February 13, 2017 Posted February 13, 2017 Ok since it's just mixed into a general thread I'll use this one instead then. thanks.
maegibbons 1287 Posted February 13, 2017 Posted February 13, 2017 Ok Just so you know, this happens regardless of whether EPG comes from SD or XMLTV Krs Mark
Luke 42243 Posted February 18, 2017 Posted February 18, 2017 This is resolved for the next release of emby server. just be aware you'll have to remove and re-add the guide data setup.
maegibbons 1287 Posted February 19, 2017 Posted February 19, 2017 Sounds great. Will test and report back. Krs Mark
maegibbons 1287 Posted February 19, 2017 Posted February 19, 2017 (edited) Hmmm... @@Luke I tried this and on duplicated channels I now only get the last channel with EPG data. The other channels just dont appear in the guide at all!! m3u data: #EXTINF:-1 channel-id="2153" tvg-id="I74410.json.schedulesdirect.org",SKY SPORTS F1 FHD http://ace-iptv.xyz:4545/live/xxxxxxxxxx/xxxxxxxxxx/615.ts #EXTINF:-1 channel-id="2154" tvg-id="I74410.json.schedulesdirect.org",SKY SPORTS F1 HD http://ace-iptv.xyz:4545/live/xxxxxxxxxx/xxxxxxxxxx/30.ts #EXTINF:-1 channel-id="2155" tvg-id="I74410.json.schedulesdirect.org" tvg-logo="https://s3.amazonaws.com/schedulesdirect/assets/stationLogos/s74410_h3_aa.png",SKY SPORTS F1 HDS http://ace-iptv.xyz:4545/live/xxxxxxxxxx/xxxxxxxxxx/1851.ts #EXTINF:-1 channel-id="2156" tvg-id="I74410.json.schedulesdirect.org" tvg-logo="https://s3.amazonaws.com/schedulesdirect/assets/stationLogos/s74410_h3_aa.png",SKY SPORTS F1 SD http://ace-iptv.xyz:4545/live/xxxxxxxxxx/xxxxxxxxxx/76.ts Only channel 2156 appears in the guide. The others have disappeared. And yes I did delete the XML EPG setup in Live TV setup and the recreated it. Perhaps I am missing a step. FYI: All the channels appear in mapping and are correctly automapped Krs Mark Edited February 19, 2017 by maegibbons
maegibbons 1287 Posted February 19, 2017 Posted February 19, 2017 Do you need an xmltv file to test the above? Let me know. Krs Mark
maegibbons 1287 Posted February 22, 2017 Posted February 22, 2017 @@Luke Can you please revisit this because duplicate EPG channels still does not work. All duplicate channels apart from the last one are now just not shown in the guide which is actually worse because you cannot even select the stream any more. Krs Mark 1
kanipek 230 Posted February 22, 2017 Author Posted February 22, 2017 @@Luke On what version of the server is this resolved? I am on 3.2.1 and I am still having this issue. Cannot map the guide listings to more than 1 channel.
Luke 42243 Posted February 22, 2017 Posted February 22, 2017 Hmmm... @@Luke I tried this and on duplicated channels I now only get the last channel with EPG data. The other channels just dont appear in the guide at all!! m3u data: #EXTINF:-1 channel-id="2153" tvg-id="I74410.json.schedulesdirect.org",SKY SPORTS F1 FHD http://ace-iptv.xyz:4545/live/xxxxxxxxxx/xxxxxxxxxx/615.ts #EXTINF:-1 channel-id="2154" tvg-id="I74410.json.schedulesdirect.org",SKY SPORTS F1 HD http://ace-iptv.xyz:4545/live/xxxxxxxxxx/xxxxxxxxxx/30.ts #EXTINF:-1 channel-id="2155" tvg-id="I74410.json.schedulesdirect.org" tvg-logo="https://s3.amazonaws.com/schedulesdirect/assets/stationLogos/s74410_h3_aa.png",SKY SPORTS F1 HDS http://ace-iptv.xyz:4545/live/xxxxxxxxxx/xxxxxxxxxx/1851.ts #EXTINF:-1 channel-id="2156" tvg-id="I74410.json.schedulesdirect.org" tvg-logo="https://s3.amazonaws.com/schedulesdirect/assets/stationLogos/s74410_h3_aa.png",SKY SPORTS F1 SD http://ace-iptv.xyz:4545/live/xxxxxxxxxx/xxxxxxxxxx/76.ts Only channel 2156 appears in the guide. The others have disappeared. And yes I did delete the XML EPG setup in Live TV setup and the recreated it. Perhaps I am missing a step. FYI: All the channels appear in mapping and are correctly automapped Krs Mark Try this example again with the next beta, thanks.
maegibbons 1287 Posted February 22, 2017 Posted February 22, 2017 (edited) @@Luke Looks like auto mapping between tvg-id and xml channel-id is badly broken in beta 115. Cannot tell yet if any improvement on multiple EPG data as my guide is broken. i will manually map in the morning to test that. krs Mark Edited February 22, 2017 by maegibbons
maegibbons 1287 Posted February 23, 2017 Posted February 23, 2017 Ok - couldnt wait till morning so got out of bed because it will destroy my recordings in current state. Have inserted manual guide mapping in livetv.xml in accordance with your new format as per: <NameValuePair> <Name>I69387.json.schedulesdirect.org-2001</Name> <Value>I69387.json.schedulesdirect.org</Value> </NameValuePair> <NameValuePair> <Name>I17153.json.schedulesdirect.org-2002</Name> <Value>I17153.json.schedulesdirect.org</Value> </NameValuePair> <NameValuePair> <Name>I50059.json.schedulesdirect.org-2003</Name> <Value>I50059.json.schedulesdirect.org</Value> </NameValuePair> And refreshed guide. So looks like you have fixed the Multiple EPG lines issue but broke tvg-id to channel-id auto mapping which was working perfectly before. Many thanks Krs Mark
Luke 42243 Posted February 23, 2017 Posted February 23, 2017 I have to revert the changes i made yesterday and find another way.
maegibbons 1287 Posted February 24, 2017 Posted February 24, 2017 Away at moment so will try end of next week. Krs Mark
maegibbons 1287 Posted March 1, 2017 Posted March 1, 2017 Hi @@Luke Can confirm that in 3.2.5.1 that Dual/multi epg guide issue is fixed AND tvg-Id to xml channel-id is automapping correctly. Well done!!! HOWEVER, there is an issue with scheduled recordings with the dual/multi epg/channel situation. If you select "Record Series" in a program on one of a multi-epg channel it does NOT select any of the episodes to be recorded. Indeed if you go in to that Series in the "series" tab it will not show any episodes in the scedule at the bottom - it is completely blank. Krs Mark
