WilhelmStroker 107 Posted July 24, 2018 Posted July 24, 2018 Yes, windows is not recommended for home assistant, so a pi is your best bet. Or a linux machine for example. I have 2 Emby clients in my living room, and what my automation does is trigger a certain activity for JUST the lights in my living room, if I'm on any of those devices. It looks a bit like this, but there's likely better examples to be found on the Home assistant forums. This is pretty much borrowed from the link I posted earlier. You need to configure both Hue and Emby as prerequisites. automation: - alias: "Emby Playback paused/stopped" trigger: - platform: state entity_id: media_player.emby__androidtv__nvidia_shield_android_tv, media_player.emby__emby_theater__xbox_one_x from: 'playing' to: 'idle' action: service: scene.turn_on entity_id: scene.livingroom_normal - alias: "Emby Playback starting" trigger: - platform: state entity_id: media_player.emby__androidtv__nvidia_shield_android_tv, media_player.emby__emby_theater__xbox_one_x to: 'playing' from: 'idle' action: - service: scene.turn_on entity_id: scene.livingroom_dim - service: light.turn_on entity_id: light.hue_lightstrip_plus_1 The scenes look like this: scene: - name: Livingroom normal entities: light.living_room_big: state: on transition: 2 brightness_pct: 100 light.living_room_small: state: on transition: 2 brightness_pct: 100 - name: Livingroom dim entities: light.living_room_big: state: on transition: 2 brightness_pct: 10 light.living_room_small: state: on transition: 2 brightness_pct: 10
hstamas 179 Posted July 24, 2018 Posted July 24, 2018 (edited) Thanks for posting that example @WilhelmStroker. I havent really attempted to try Home Assistant yet as I would need to get a Pi set up first but have been studying examples trying to familiarize myself why the syntax used. Would you know what could be added to your above example to only get this automation to happen when watching a movie and be ignored for TV and Live TV? I would be using Kodi as my player so maybe it reports something that could trigger it or possibly just add a video length condition and have it trigger only if the video is of a certain duration? I don't want my lights to go off when watching regular TV shows or live tv. Edited July 24, 2018 by hstamas
WilhelmStroker 107 Posted July 24, 2018 Posted July 24, 2018 Not sure, I had a look around but didnt really find much for Home Assistant, although apparently there's a Kodi plugin that's mentioned here: https://community.home-assistant.io/t/dim-lights-when-playing-media-cancel-or-delay/6317 Not sure if that would work with emby though but worth a test.
hstamas 179 Posted December 13, 2018 Posted December 13, 2018 Just wanted to share that I finally found a solution for integrating Philips Hue lighting with Emby. Using this webhooks plugin (I believe you need to be using the latest Emby beta for this to work) along with the IFTTT webhooks service got it working perfectly for me: https://github.com/nxenos83/emby.plugin.Webhooks 1
DelSol 10 Posted December 13, 2018 Posted December 13, 2018 hstamas can you please share how you managed to get this to work? I added my IFTTT maker url including the api key in the first text field, checked movies and my options and entered the name of my webhook "turn_on_lights" that I created in IFTTT. this does not work for me.
Luke 42252 Posted December 14, 2018 Posted December 14, 2018 Did you verify in IFTTT that it received the request and then attempted to act on it?
DelSol 10 Posted December 14, 2018 Posted December 14, 2018 when I fire the IFTTT trigger manually via the URL or another app it works perfectly, but it seems that emby does not trigger the webhook at all. this is my setup:
hstamas 179 Posted December 14, 2018 Posted December 14, 2018 Did you verify in IFTTT that it received the request and then attempted to act on it? Yes the IFTTT trigger works properly. Like I mentioned this did NOT work for me using the stable release of the server. Once I updated to the beta (Mac OSX) it started working.
hstamas 179 Posted December 14, 2018 Posted December 14, 2018 (edited) hstamas can you please share how you managed to get this to work? I added my IFTTT maker url including the api key in the first text field, checked movies and my options and entered the name of my webhook "turn_on_lights" that I created in IFTTT. this does not work for me.Did you make sure your event name in IFTTT is the exact same name used in the web hook web url? I had an issue early on not knowing what to put in the placeholder part of the url. attached are my setups in both the plugin and IFTTT. Your event name has to be the exact same thing in both places. Now I havent watched a movie in about a week. I sure hope this hasn't stopped working and I am just not aware of it?? Just checked and it is still working as expected. Edited December 14, 2018 by hstamas
Biofects 4 Posted January 10, 2019 Posted January 10, 2019 (edited) Hello everyone, I am very vanilla (2 weeks new) to Emby and loving it! I was searching for a phillips hue plugin and found this article. I was bummed for about 30 min, that the original plugin was no longer working. Then I said I'll see if I can fix it. Well I have it working for Emby 3.6.0.84. I do have the fix for 3.5 also, ill need to compile it. I will fork the original and publish in the next day or so. Do I just link to my github here when I publish? I would love feedback. Thanks Edited January 10, 2019 by Biofects
hstamas 179 Posted January 10, 2019 Posted January 10, 2019 Hi @@Biofects. The plugin is still working for me as is so Im curious what isnt working on your end? Is it just the need to be running the beta server that is the issue? I'd be happy to test out anything you create that might make this an even better plugin. @@Luke should be able to give you instructions on how to get a plugin submitted to the catalog once you get to that stage.
Biofects1 1 Posted January 10, 2019 Posted January 10, 2019 Thanks @Luke and @hstamas. I have published release here Biofects. The reason I went down this road was I could not get the original plugin to work with my new install of Emby Server not the beta version. I also tried to update the base code to be on later versions. Please let me know if you have issues on the install and I will try to fix them. Thanks.
Luke 42252 Posted January 10, 2019 Posted January 10, 2019 To work with the beta version you'll need to use the beta nuget package. the version of the nuget package corresponds to the version of emby server.
Biofects1 1 Posted January 10, 2019 Posted January 10, 2019 (edited) Oh Sorry,I miss spoke. I have the latest nuget package, and working the update is Working in Emby 3.6.0.78-beta. Also I messed up my account and I am @Biofects Edited January 10, 2019 by Biofects1
hstamas 179 Posted January 10, 2019 Posted January 10, 2019 (edited) My bad guys. I though we were talking about the Webhooks plugin that this discussion thread turned into (which works well with the latest Emby server beta). @@Biofects1, I will definitely test out your updated Hue specific plugin this weekend and give you feedback here. Edited January 10, 2019 by hstamas
GreyBeard 22 Posted January 11, 2019 Posted January 11, 2019 I so wish this could somehow be tied to the cinema mode plugin. I used to use the Cinema Experience plugin with Kodi. It made for a very cool "movie night" experience. Select play for the movie and before movie starts dim certain lights, start music and play trivia slides for 10 minutes. End trivia, turn off lights, turn on light behind tv and play two trailers. Play the movie. Movie gets paused, raise lights to dim level. Movie ends, raise lights to normal level. The only thing they didn't have figured out when I was using it was how to save a time credits start for each movie to raise the lights to dim level then full when it ends. Add in the ability to control the curtains I'll eventually have to change the screen size for 2.35:1 vs 1.85:1 and we're golden. Really wish I knew more about programming.....
GreyBeard 22 Posted January 11, 2019 Posted January 11, 2019 BTW, the plugin from @@Biofects works fine in the latest beta. (Which for some reason my dashboard says I'm running 4.0.0.0 beta instead of what I think is 3.6.85?) Thanks for the fix. Looking forward to more options such as colors and controlling more than one group doing different things.
Biofects1 1 Posted January 11, 2019 Posted January 11, 2019 Thanks @@GreyBeard, I want to add some more features soon. Starting simple
hstamas 179 Posted January 11, 2019 Posted January 11, 2019 Thanks @Luke and @hstamas. I have published release here Biofects. The reason I went down this road was I could not get the original plugin to work with my new install of Emby Server not the beta version. I also tried to update the base code to be on later versions. Please let me know if you have issues on the install and I will try to fix them. Thanks. Had the chance to quickly test out the plugin last night and it work perfectly. In my use case I would need the ability to choose which specific lights to control or if thats not possible be able to trigger a scene instead? Also the ability to have different actions based on what playback is doing, IE: Play = Turn off / Pause = Raise to 50% etc. Great work so far!
Biofects 4 Posted January 11, 2019 Posted January 11, 2019 Had the chance to quickly test out the plugin last night and it work perfectly. In my use case I would need the ability to choose which specific lights to control or if thats not possible be able to trigger a scene instead? Also the ability to have different actions based on what playback is doing, IE: Play = Turn off / Pause = Raise to 50% etc. Great work so far! Thanks for testing, Im hoping to have some time this weekend to start adding features as you have described. Like I said I am still very vanilla to Emby, so it might take a bit. I have added a function to auto discover the bridge, just need to add a few more features before next release.
Biofects 4 Posted January 27, 2019 Posted January 27, 2019 (edited) Hey Everyone, Sorry for the delay, I have added a couple features: Get the latest here Biofects Emby Phillips Hue Plugin Multiple Light Group Support Individual Dim Control for Play Pause and Stop Please test and let me know what you think. I also want to give a shout out to a bud NicK who helped me with C# and getting bugs worked out. Edited January 27, 2019 by Biofects
DarzLir 0 Posted January 28, 2019 Posted January 28, 2019 OMG, a few months ago I read something about the possibilities of Philips HUE and Emby, but I did not have any device and I was not interested anymore. But last Christmas I received an Amazon Dot 3rd and a week ago I bought a starter kit with two bulbs and a bridge. I just tried it and it works great! I created a routine with Alexa, an "emby mode", where Alexa and a Broadlink RM mini 3 open the TV app, decrease the brightness and turn the lights blue. But this works more directly and by devices, a light bulb in the bedroom for example with settings different from those of the living room. I guess the next step could be to customize the colors of the groups or devices. And I think the greatest (and maybe most complicated) thing is to detect that you have logged in Emby in a device and launch a change in the lights. For example: In the living room I have lights in warm white mode so, when you enter and log in Emby App, the lights change to a certain color, then we got the preferences of play, pause and stop and when you disconnect or log out you return to the previous setting or another you want. I do not know if it is possible because I do not know what can or can not be done. But since I do not know too much about programming, at least my contribution is to try and give ideas. thank you very much @@Biofects and hit it
