PhyberApex 16 Posted February 8, 2017 Posted February 8, 2017 (edited) Hey, I just tried to reach /swagger-ui/index.html on my emby installation but it only returns "One or more errors occurred." On a side note. Are there no release notes for 3.2.0.0? Edit: Log file says: 2017-02-08 12:00:38.7648 Error HttpServer: Error processing request *** Error Report *** Version: 3.2.0.0 Command line: /usr/lib/emby-server/bin/MediaBrowser.Server.Mono.exe -programdata /var/lib/emby-server -ffmpeg /usr/bin/ffmpeg -ffprobe /usr/bin/ffprobe -restartpath /usr/lib/emby-server/restart.sh Operating system: Unix 3.16.0.4 64-Bit OS: True 64-Bit Process: True Mono: 4.6.2 (Stable 4.6.2.7/08fd525 Mon Nov 28 20:21:32 UTC 2016) Processor count: 4 Program data path: /var/lib/emby-server Application directory: /usr/lib/emby-server/bin System.IO.DirectoryNotFoundException: Could not find a part of the path "/usr/lib/emby-server/bin/dashboard-ui/swagger-ui/index.html". at System.IO.FileStream..ctor (System.String path, System.IO.FileMode mode, System.IO.FileAccess access, System.IO.FileShare share, System.Int32 bufferSize, System.Boolean anonymous, System.IO.FileOptions options) [0x001cf] in <8f2c484307284b51944a1a13a14c0266>:0 at System.IO.FileStream..ctor (System.String path, System.IO.FileMode mode, System.IO.FileAccess access, System.IO.FileShare share, System.Int32 bufferSize) [0x00000] in <8f2c484307284b51944a1a13a14c0266>:0 at (wrapper remoting-invoke-with-check) System.IO.FileStream:.ctor (string,System.IO.FileMode,System.IO.FileAccess,System.IO.FileShare,int) at Emby.Common.Implementations.IO.ManagedFileSystem.GetFileStream (System.String path, MediaBrowser.Model.IO.FileOpenMode mode, MediaBrowser.Model.IO.FileAccessMode access, MediaBrowser.Model.IO.FileShareMode share, System.Boolean isAsync) [0x00045] in <42c5174dc9d74c7a87560f62bb636308>:0 at MediaBrowser.WebDashboard.Api.PackageCreator.GetRawResourceStream (System.String path) [0x0000d] in <53ff78d6dad44067876711102587fb96>:0 at MediaBrowser.WebDashboard.Api.PackageCreator+<GetResource>c__async0.MoveNext () [0x00021] in <53ff78d6dad44067876711102587fb96>:0 --- End of stack trace from previous location where exception was thrown --- ~Cheers Edited February 8, 2017 by PhyberApex
Luke 42203 Posted February 8, 2017 Posted February 8, 2017 Swagger has been down since 3.1, it is on our to do list to restore it. Thanks. 1
Luke 42203 Posted September 9, 2017 Posted September 9, 2017 Swagger will be back for the next release and will look better than ever:
