Chillout 111 Posted February 5, 2017 Posted February 5, 2017 Feature Request: Is it possible to add navigation arrows to the EPG guide in Emby Theater to scroll into the future? I use a mouse and the wheel will let me scroll up and down but there is no way to go left and right without using the keyboard.
Luke 42245 Posted February 5, 2017 Posted February 5, 2017 Hi, enable desktop mode and then you'll get a scrollbar
Chillout 111 Posted February 6, 2017 Author Posted February 6, 2017 Thanks for your quick reply Luke, Desktop mode brought the scroll bar but the scaling made the Library bar scale to be much smaller. Is there a way to adjust the scaling within Theater? DESKTOP: AUTO MODE:
Luke 42245 Posted February 6, 2017 Posted February 6, 2017 Right will desktop mode will assume that you're close up with a mouse and keyboard. TV nice will assume you're at 10ft
Chillout 111 Posted February 6, 2017 Author Posted February 6, 2017 I watch Theater on a TV with a mouse.. Is it possible to add the EPG guide scroll bar to the TV mode? Thanks, Chris
