Hydro 5 Posted February 5, 2017 Posted February 5, 2017 Hi, I'm new to emby plugin development and to c# so maybe this question is easy for you. I'm trying to create a notification plugin for my home automation system, so I copied Pushbullet .sln But every time I change namespace, I've got this error when I try to go to configuration page : Uncaught TypeError: Cannot read property 'getAttribute' of undefined at Object.loadView (viewcontainer-lite.js?v=3.1.6235.2624:42) at ViewManager.loadView (viewmanager.js?v=3.1.6235.2624:151) at loadContent (router.js?v=3.1.6235.2624:385) at router.js?v=3.1.6235.2624:129 at Object.execCb (require.js?v=3.1.6235.2624:1693) at Module.check (require.js?v=3.1.6235.2624:881) at Module.enable (require.js?v=3.1.6235.2624:1173) at Module.init (require.js?v=3.1.6235.2624:786) at require.js?v=3.1.6235.2624:1457 I try with Pushbullet or Pushover sln but same problem. I searched for old name, but it didn't find so I guess I change every occurence. Any idea where this error come from ?
Hydro 5 Posted February 5, 2017 Author Posted February 5, 2017 I copied Pushbullet plugin from GitHub, I change every namespace that I found and when I try to go to configuration page I've got this in chrome console.
