s0n1q 0 Posted February 2, 2017 Posted February 2, 2017 Hi, everyone! Having issue with syncing to android mobile. When i choose "original" quality, my files converted to Opus. But i expect FLAC, as an original file. Logs in attachment. What I'm doing wrong? Or may be some settings for transcoding for each type of quality? transcoding_flac_to_opus.txt
Luke 42244 Posted February 2, 2017 Posted February 2, 2017 Hi @@s0n1q, thanks for the report. I can reproduce this. I'm looking into it.
s0n1q 0 Posted February 7, 2017 Author Posted February 7, 2017 @@Luke after upgading to 3.2.0 server, still having this issue. Tried to find out where are the profiles located, but failed. In server logs for sync find this lines: 2017-02-07 14:08:27.1037 Info SyncManager: Profile: Unknown Profile, No direct play profiles found for Path: /home/torrent/Music/Mr. Oizo - 2016 - All Wet/07. End Of The World (feat. Skrillex).flac 2017-02-07 14:08:27.1110 Info TaskManager: Queueing task SyncConvertScheduledTask 2017-02-07 14:08:27.1110 Info TaskManager: Executing Convert media 2017-02-07 14:08:27.1172 Info App: Profile: Unknown Profile, No direct play profiles found for Path: /home/torrent/Music/Mr. Oizo - 2016 - All Wet/07. End Of The World (feat. Skrillex).flac 2017-02-07 14:08:27.1451 Info MediaEncoder: /bin/ffmpeg -i file:"/home/torrent/Music/Mr. Oizo - 2016 - All Wet/07. End Of The World (feat. Skrillex).flac" -threads 0 -vn -ab 192000 -ac 2 -id3v2_version 3 -write_id3v1 1 -y "/var/lib/emby-server/sync/0d0b1a6d770f4bddaf5c5378e8dc2262/15f0d1c3611e44fe88fa730bf4c78b4d/16ae2e4175df4dc9acfd00e6d4c673f2.opus" Where this profiles is located and how to edit them just to sync Flac files to mobile without trancoding?
Solution Luke 42244 Posted February 7, 2017 Solution Posted February 7, 2017 It will be resolved with an update to the app, thanks. 1
