Beta "Issues"
Go to solution Solved by ebr,
skidmarks
music search is freezing up the roku again.  Will remove those two libraries and see if it is resolved again by doing that...  Will report back!
skidmarks
I dont get it...  Now search is working, with all libraries enabled.  I hardly ever use a search function.  It is not usually needed if there is a way to filter categories / libraries in a logical way.  Hopefully, as the beta movies along, more "view by" options can be incorporated into it.
