r0bot 1 Posted February 1, 2017 Posted February 1, 2017 Hello, I know how to turn off missing episodes per user but that is not what I am looking for. As the admin for my server at my household I handle missing episodes for shows so i commonly use the Episode view and then sort by missing. For some shows however I know there is episodes I will never get, would it be possible for disable these listing without turning off missing episodes in total? More specifically even still, what is there is only 1 episode from a show that is still airing I know I can never get but thetvdb or someone lists it as aired, any way to remove this from the list, other than a dummy movie file with the episode name which I have done in the past. Thanks, r0bot
ebr 16309 Posted February 1, 2017 Posted February 1, 2017 The feature is now per library so you can manage it that way. Going all the way to the show level is a possibility for the future.
