waspsoton 0 Posted January 31, 2017 Posted January 31, 2017 i did a quick match of some channels but now i have the time do match all of them but when i click on the icon to do it all i see is nothing. see the screenshot. any ideas??
Luke 42243 Posted January 31, 2017 Posted January 31, 2017 Hi there @@waspsoton, we're very sorry to hear about this. In order for us to best help you, please provide the information requested in how to report a problem. thanks !
Luke 42243 Posted February 1, 2017 Posted February 1, 2017 hi @@waspsoton, did you forget to attach the file? thanks !
waspsoton 0 Posted February 2, 2017 Author Posted February 2, 2017 (edited) hi @@waspsoton, did you forget to attach the file? thanks ! lol Edited February 2, 2017 by waspsoton
maegibbons 1287 Posted February 2, 2017 Posted February 2, 2017 (edited) Ok You are having name resolution failures - what system is the server installed on? Check out your dns settings. You will have all sorts of issues without proper name resolution. Otherwise, download the m3u file from your provider and store on your local drive. THEN point emby at your local file. However, your streams wont work anyway without name resolution. KRs Mark Edited February 2, 2017 by maegibbons
waspsoton 0 Posted February 2, 2017 Author Posted February 2, 2017 my server is install on a mac. now can I sort the name resolution failures?? I can download the m3u file but then I wont get any changes made from the supplier. but I will try that tonight once I get in from work. I do see I am not the only one having this problem.
maegibbons 1287 Posted February 2, 2017 Posted February 2, 2017 1st Make sure you read the PM I sent you. Whilst the symptoms may be the same, the reasons may not be. Your log clearly shows name resolution issues. I have seen one similar name resoltion post recently which was affecting a qnap user. The build for both platforms "may" be creating a similar problem or it might be totally unrelated. Your provider will not change their streams much. However your big problem currently is name resolution which may or may not be an emby build issue. it is more likely to be your machine setup. Check that you can ping www.bbc.co.uk and uk-mega-iptv.is-found.org from the terminal prompt using the same user that emby is installed as. Krs Mark
Gabbe222 0 Posted February 2, 2017 Posted February 2, 2017 Store The epg local, dont use url, then it Will work.
waspsoton 0 Posted February 3, 2017 Author Posted February 3, 2017 (edited) here is the log file with some important info. also sorting the guide on my mac hasn't help either.i have just done a full reinstall and i now can't match any of my channels and the guide. and i see i can't download a beta on the mac either emby log.rtf Edited February 3, 2017 by waspsoton
maegibbons 1287 Posted February 3, 2017 Posted February 3, 2017 This Log is from 31/01. Early parts of this log still shows Name resolution errors. At 22:00 name resolution seems to be working and it loads your m3u. It looks as though it tunes to a channel. If you have "automatically convert recordings to stream friendly format" for now switch it off to remove any ffmpeg complication. Restart emby. Refresh guide. Repost new log. Krs Mark
Luke 42243 Posted February 3, 2017 Posted February 3, 2017 Hi @@waspsoton Your machine is having trouble accessing the internet 2017-01-31 09:09:03.2736 Error HttpClient: Error getting response from http://uk-mega-iptv.is-found.org:25461/get.php?username=unknow&type=m3u&output=ts *** Error Report *** Version: 3.1.5.0 Command line: /Applications/Emby.Server.Mac.app/Contents/MonoBundle/Emby.Server.Mac.exe /Applications/Emby.Server.Mac.app/Contents/MonoBundle/Emby.Server.Mac.exe Operating system: Unix 15.6.0.0 64-Bit OS: True 64-Bit Process: False Mono: 4.6.2 (mono-4.6.0-branch/ac9e222) Processor count: 4 Program data path: /Users/unknow/.config/emby-server Application directory: /Applications/Emby.Server.Mac.app/Contents/MonoBundle System.AggregateException: One or more errors occurred. ---> System.Net.WebException: Error: NameResolutionFailure at System.Net.HttpWebRequest.EndGetResponse (System.IAsyncResult asyncResult) [0x00064] in <5071a6e4a4564e19a2eda0f53e42f9bd>:0 at System.Threading.Tasks.TaskFactory`1[TResult].FromAsyncCoreLogic (System.IAsyncResult iar, System.Func`2[T,TResult] endFunction, System.Action`1[T] endAction, System.Threading.Tasks.Task`1[TResult] promise, System.Boolean requiresSynchronization) [0x00014] in <8f2c484307284b51944a1a13a14c0266>:0 --- End of inner exception stack trace --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0004e] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x0002e] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x0000b] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () [0x00000] in <8f2c484307284b51944a1a13a14c0266>:0 at Emby.Common.Implementations.HttpClientManager.HttpClientManager+<SendAsyncInternal>d__20.MoveNext () [0x003ff] in <a7c9a1654c74440097ba2c85efc87818>:0 ---> (Inner Exception #0) System.Net.WebException: Error: NameResolutionFailure at System.Net.HttpWebRequest.EndGetResponse (System.IAsyncResult asyncResult) [0x00064] in <5071a6e4a4564e19a2eda0f53e42f9bd>:0 at System.Threading.Tasks.TaskFactory`1[TResult].FromAsyncCoreLogic (System.IAsyncResult iar, System.Func`2[T,TResult] endFunction, System.Action`1[T] endAction, System.Threading.Tasks.Task`1[TResult] promise, System.Boolean requiresSynchronization) [0x00014] in <8f2c484307284b51944a1a13a14c0266>:0 <--- System.AggregateException at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0004e] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x0002e] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x0000b] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () [0x00000] in <8f2c484307284b51944a1a13a14c0266>:0 at Emby.Common.Implementations.HttpClientManager.HttpClientManager+<SendAsyncInternal>d__20.MoveNext () [0x003ff] in <a7c9a1654c74440097ba2c85efc87818>:0 InnerException: System.Net.WebException System.Net.WebException: Error: NameResolutionFailure at System.Net.HttpWebRequest.EndGetResponse (System.IAsyncResult asyncResult) [0x00064] in <5071a6e4a4564e19a2eda0f53e42f9bd>:0 at System.Threading.Tasks.TaskFactory`1[TResult].FromAsyncCoreLogic (System.IAsyncResult iar, System.Func`2[T,TResult] endFunction, System.Action`1[T] endAction, System.Threading.Tasks.Task`1[TResult] promise, System.Boolean requiresSynchronization) [0x00014] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Net.HttpWebRequest.EndGetResponse (System.IAsyncResult asyncResult) [0x00064] in <5071a6e4a4564e19a2eda0f53e42f9bd>:0 at System.Threading.Tasks.TaskFactory`1[TResult].FromAsyncCoreLogic (System.IAsyncResult iar, System.Func`2[T,TResult] endFunction, System.Action`1[T] endAction, System.Threading.Tasks.Task`1[TResult] promise, System.Boolean requiresSynchronization) [0x00014] in <8f2c484307284b51944a1a13a14c0266>:0 2017-01-31 09:09:03.2761 Error App: Error getting channel list *** Error Report *** Version: 3.1.5.0 Command line: /Applications/Emby.Server.Mac.app/Contents/MonoBundle/Emby.Server.Mac.exe /Applications/Emby.Server.Mac.app/Contents/MonoBundle/Emby.Server.Mac.exe Operating system: Unix 15.6.0.0 64-Bit OS: True 64-Bit Process: False Mono: 4.6.2 (mono-4.6.0-branch/ac9e222) Processor count: 4 Program data path: /Users/unknow/.config/emby-server Application directory: /Applications/Emby.Server.Mac.app/Contents/MonoBundle MediaBrowser.Model.Net.HttpException: One or more errors occurred. ---> System.AggregateException: One or more errors occurred. ---> System.Net.WebException: Error: NameResolutionFailure at System.Net.HttpWebRequest.EndGetResponse (System.IAsyncResult asyncResult) [0x00064] in < What you want to do is make sure it has an active internet connection. Additionally, if running within Docker or a VM, make sure you have configured a network connection for the container. Let us know if this helps. Thanks !
