PenkethBoy 2068 Posted January 30, 2017 Posted January 30, 2017 Could the system tray icon be updated with the name of the server? not an issue if you only run one server - but its impossible to tell which is which when you have more than one running for testing - other than running up the dashboard Also could the exe report its name to the system also as "Emby - Servername" so you can distinguish in task explorer/process explorer etc Trivial change to do but would make thing easier Thanks 3
