conrad666 0 Posted January 30, 2017 Posted January 30, 2017 (edited) Hello Have try to get EPG working a few day now, but with now sucess.... (anotherthings work like a charm like trascoding/picon etc) 1.Have a Subscripe from Ra***iptv there you get a m3U file look like this http://clientpotal.link/get.php?userbame=xxxxxx&password=xxxxxxxx&type=m3u plus&output=ts 2 That file you put in, Emby live tv "TUNER DEVICE" 3. Then in Emby "GUIDE PROVIDERS" you put XMLtv have tried this two http://secure.clientportal.link/epg/guideextra.xml.gz AND http://www.vuplus-community.net/rytec/rytecxmltvnordic.gz tere you see a dowloads "greeen bar" 4, Then MAP channels,, there i see noting happens Think something is missing ?? have used this to "split the m3u file and only select nordic channels with this https://iptvm3ueditor.codeplex.com becuse the list get so long Exempel one channel look like this #EXTINF:0, tvg-id="TV4 SE" tvg-logo="http://secure.clientportal.link/picons/tv4se.png"tvg-name="TV4 SE" group-title="Sweden",TV4 SE http://clientportal.link/live/xxxxxxxxxxxxxxx/xxxxxxxxxxxx/11532.ts And in EPG window like picture Think some nummering issue??? regardas C Edited January 30, 2017 by conrad666
Luke 42242 Posted January 30, 2017 Posted January 30, 2017 Hi there, please run the refresh guide scheduled task. Then when it completes, please attach the complete emby server log. you can learn how to do that here: https://emby.media/community/index.php?/topic/739-how-to-report-a-problem/ Thanks !
conrad666 0 Posted February 1, 2017 Author Posted February 1, 2017 (edited) Hello Did some restart and used SHEDULES DIRECT, two instances from different channel provider instead of XMLTV than it worked right from the box .. is little mapping and a little coast if want to use it...But is was not so mush hazzel... .If you want to backup channels mapping u need a premium account??? Edited February 1, 2017 by conrad666
Luke 42242 Posted February 1, 2017 Posted February 1, 2017 Hello @@conrad666, the automated Emby backup plugin requires Emby Premiere. You can learn more about that here: https://emby.media/premiere.html However you can always backup manually: https://emby.media/community/index.php?/topic/10427-how-to-migrate-emby-server Thanks !
conrad666 0 Posted February 2, 2017 Author Posted February 2, 2017 thanks you have get you à new client EMBY rock Conny
