BAS 225 Posted January 29, 2017 Posted January 29, 2017 I was wondering if we could have a setting similar to the android tv app where we can turn off all the navigational backdrops everywhere in this interface and only have them be displayed when a user enters a item for more details.
BAS 225 Posted February 3, 2017 Author Posted February 3, 2017 I'm going to bump this in hopes in great traction from other users or perhaps @@ebr missed it.. I'm mainly after this as I find the performance of backdrops on Roku distracting to the smoothness of the scrollers and loading times. I much prefer only having backdrops on the landing details page of an item. Also in order for me to roll this to my external server users for additional testing results this option is required before I will do this as I want to limit all these backdrop art requests for bandwidth purposes and also for them to be able scroll and navigate more quickly. through the new interface. Thanks for considering this.
ebr 16335 Posted February 3, 2017 Posted February 3, 2017 We do probably need to see some more support for this option from other users...
Happy2Play 9811 Posted February 3, 2017 Posted February 3, 2017 Well if it is a performance issue on some models then yes it needs to be an optional.
ebr 16335 Posted February 3, 2017 Posted February 3, 2017 Well if it is a performance issue on some models then yes it needs to be an optional. I have not seen any performance issues.
Jdiesel 1435 Posted February 3, 2017 Posted February 3, 2017 Seems pretty snappy on my Roku 3 and Premiere+
Happy2Play 9811 Posted February 3, 2017 Posted February 3, 2017 I don't see an issue either but mine is a wired Ultra. I would assume wired vs wireless will be a factor also. But without know all the information of models and connections everything is just a guess.
BAS 225 Posted February 3, 2017 Author Posted February 3, 2017 (edited) Ok im back, yes I have a Roku 4, backdrops fine, wireless. I have Roku Stick local wireless, backdrop performance horrendous, even with excellent signal. So if its hardware then yes, remote users have Roku sticks or earlier gen Roku's for me and pretty sure all would be wireless. Would love the new design of this app and are great at getting me feedback but I would need this toggle before I would subject myself to their requests and issues to pass along. Edited February 3, 2017 by BAS
BAS 225 Posted February 18, 2017 Author Posted February 18, 2017 OK well I have rolled this to some of my external family testers and have had complaints about scrollers and general overall loading times on views. I took my Roku stick out of my house like I tend to do on vacations and tested and had extreme problems navigating and getting around even the device completely rebooting on me just from moving around. It all appears to be the loading of backdrops on each navigation move that really dips the performance. I know this isnt normal use case scenario but at the same time would like to use my Roku when I'm visiting family and friends. '.
ebr 16335 Posted February 18, 2017 Posted February 18, 2017 I just implemented a setting in the app. Will be available with the next update. 1
BAS 225 Posted February 19, 2017 Author Posted February 19, 2017 I just implemented a setting in the app. Will be available with the next update. It really is much appreciated. Thank you. 1
Solution ebr 16335 Posted February 20, 2017 Solution Posted February 20, 2017 This should be available in 1.19.17.
BAS 225 Posted February 21, 2017 Author Posted February 21, 2017 Tested and working correctly. Speed and efficiency of navigation for external connections and lowered powered devices is much improved. Thank you.
