mondwa 4 Posted January 29, 2017 Posted January 29, 2017 So after new update i can no longer get to play my movies from either on xbox one or ps4 on the Web browser. Do i need to buy premier app now to be able to play on web browser?
mondwa 4 Posted February 8, 2017 Author Posted February 8, 2017 Hi, what web URL are you using? I am using the xbox one microsoft internet explorer app and then using ddns to look to my server. when it get to emby it tells me now that my cursor will not show up and i can no longer do anything from that point no matter what button i try. I can still get to it with PS4 web browser and using computer browser
mondwa 4 Posted February 8, 2017 Author Posted February 8, 2017 sorry i was traveling with no internet , i will be quicker to respond now. Thanks for the help
Luke 42243 Posted February 8, 2017 Posted February 8, 2017 Ok yea, the only web app we are actively testing on xbox one and ps4 is the Emby Theater web app, which can be found at http://tv.emby.media As it turns out you can load the cursor by clicking the settings menu on the controller and switching the browser mode, but the xbox one browser is going to make you do that every single time. For the best experience possible I would use the Emby Theater web app. Thanks !
mondwa 4 Posted February 8, 2017 Author Posted February 8, 2017 Ok yea, the only web app we are actively testing on xbox one and ps4 is the Emby Theater web app, which can be found at http://tv.emby.media As it turns out you can load the cursor by clicking the settings menu on the controller and switching the browser mode, but the xbox one browser is going to make you do that every single time. For the best experience possible I would use the Emby Theater web app. Thanks ! ok yea that works great. thank you so with the app i have a question. If i get the app will all my xboxs and ps4 be able to use it ? or will i have to purchase the app for each device?
mondwa 4 Posted February 8, 2017 Author Posted February 8, 2017 Awesome thank you so much Luke for all the help, i have used emby since mediabrowser days and after all you guys have done i think its time i get the lifetime subscription next payday. Thanks again and feel free to close thread if you want
