tidusjar 55 Posted February 9, 2017 Posted February 9, 2017 Go to C:\Ombi and manually run the .exe to see what the error is. It will appear in the console.
Blueeyiz702 223 Posted February 9, 2017 Posted February 9, 2017 Go to C:\Ombi and manually run the .exe to see what the error is. It will appear in the console.thats problem,there is no exe? In the ombi folder. Sent from my Rooted Z987 on the Deathstar via Tapatalk
Blueeyiz702 223 Posted February 9, 2017 Posted February 9, 2017 no cant find it either? Sent from my Rooted Z987 on the Deathstar via Tapatalk
CBers 7554 Posted February 9, 2017 Posted February 9, 2017 no cant find it either? I'd trash it and start again 1
Blueeyiz702 223 Posted February 9, 2017 Posted February 9, 2017 I'd trash it and start again just delete all the files,or is there certain way to uninstall? Sent from my Rooted Z987 on the Deathstar via Tapatalk
CBers 7554 Posted February 9, 2017 Posted February 9, 2017 just delete all the files,or is there certain way to uninstall? Sent from my Rooted Z987 on the Deathstar via Tapatalk Just delete the C:\Ombi folder. NSSM is OK, so all you have to do is unzip the files to where you want (I'd put it in C:\ProgramData\Ombi) and then do the NSSM commands again. Then open your browser to localhost:3579.
Blueeyiz702 223 Posted February 9, 2017 Posted February 9, 2017 (edited) Just delete the C:\Ombi folder. NSSM is OK, so all you have to do is unzip the files to where you want (I'd put it in C:\ProgramData\Ombi) and then do the NSSM commands again. Then open your browser to localhost:3579. ill try again later, before i kick laptop out of house. Sent from my Rooted Z987 on the Deathstar via Tapatalk Edited February 9, 2017 by blueeyiz7021
Blueeyiz702 223 Posted February 9, 2017 Posted February 9, 2017 i also get this when i start service? Sent from my Rooted Z987 on the Deathstar via Tapatalk
SuperPotatoMen 41 Posted February 9, 2017 Author Posted February 9, 2017 (edited) Pleas copy past the whole error from the command prompt. We miss now the whole error log output. (you need to be administration or root permission) Edited February 9, 2017 by SuperPotatoMen
BAS 225 Posted February 9, 2017 Posted February 9, 2017 (edited) https://emby.media/community/index.php?/topic/44267-ombi-for-emby/?p=417623 All the things mentioned in here are fixed I havent retested newsletter yet. Thank you. Now just waiting on a place for that custom art file Edit: I did get around to testing the newsletter again, still getting this message in the email received. "This email is only available on devices that support HTML." Edited February 9, 2017 by BAS 2
ebr 16334 Posted February 9, 2017 Posted February 9, 2017 You don't need an Emby server to run Ombi, as it plugs into others services as well. I understand but he was saying he didn't have a machine to run Ombi on and, since he is here I assumed he had an Emby server running somewhere and that is the same machine on which he would run Ombi.
Blueeyiz702 223 Posted February 9, 2017 Posted February 9, 2017 Pleas copy past the whole error from the command prompt. We miss now the whole error log output. (you need to be administration or root permission) thats all it giving me to show you. Sent from my Rooted Z987 on the Deathstar via Tapatalk
gjviii 48 Posted February 9, 2017 Posted February 9, 2017 I have 2 questions, is there a setting somewhere that you can schedule when the notifications are sent to the users? Also, is there a place to enter the Emby server name for the notifications? I'm running 2 servers and would like to be able to enter the server name so i know which one the email is coming from Thank you
sh0rty 727 Posted February 9, 2017 Posted February 9, 2017 @@tidusjar Is there any chance to get the german titles and plot of Movies/Series?
Blueeyiz702 223 Posted February 9, 2017 Posted February 9, 2017 Pleas copy past the whole error from the command prompt. We miss now the whole error log output. (you need to be administration or root permission) This is want happens when i run embi.exe
Blueeyiz702 223 Posted February 9, 2017 Posted February 9, 2017 (edited) Did you follow this guide:http://www.htpcguides.com/install-plex-requests-net-windows-system-service/ and download the zip file from here:https://ci.appveyor.....1401/artifacts ? Once the zip has been downloaded, unblock the zip file and then extract it somewhere. Go into the extracted folder and run Ombi.exe The zip file you download PlexRequest,thats the one you unblock has no Ombi.exe file included so it can't be run? The absolute path to the PlexRequests.exe should be c:\Ombi\Ombi.exe and notc:\Ombi\Release\Ombi.exe,thats my problem i just notice. if you have the release part included it wont work.but nobody mentioned that! And i still have same problem.Ugh Edited February 10, 2017 by blueeyiz7021
econ 74 Posted February 10, 2017 Posted February 10, 2017 It does have ombi.exe in it. It looks like you are running it from the command prompt above.
the1legend 45 Posted February 10, 2017 Posted February 10, 2017 I'm really liking the work that you have put in to this app, thanks! I have a question about the landing page, the page shows that the server is off-line. Where do I go to configure this to reflect the real status of Emby (which is running)? Also, when selecting an issue with a TV show, you can only select the whole show and not just an episode. This there a support forum that I should be using to ask questions? Thanks again for your hard work (donation coming soon).
Blueeyiz702 223 Posted February 10, 2017 Posted February 10, 2017 @@CBers,look at the instructions and tell me whats missing. And it says unblock then unzip PlexRequests to C:\Ombi,in my case its C:\ProgramData\Ombi. But in that folder there is no Ombi.exe? for me to run? Everybody is telling me to run Ombi.exe,how can i when its not included in zip?
Diedrich 380 Posted February 10, 2017 Posted February 10, 2017 (edited) Ombi 2.1.1404 does not match Emby nor Sonarr https://github.com/tidusjar/Ombi/issues/1093 Ombi 2.1.1404 shows e11-15 as available, skips e16, and then shows e17 as available. Sonarr and Emby agree that the only media on the disk is e11 and e12. This was a general test of Ombi to see if it was showing the correct content from Emby. According to this, it's not. The checkboxes can not be removed indicating to me that it's showing what it thinks is on the disk even though the media doesn't exist except for s11, s12. Sonarr Emby Edited February 10, 2017 by dvgmar
Blueeyiz702 223 Posted February 10, 2017 Posted February 10, 2017 It does have ombi.exe in it. It looks like you are running it from the command prompt above. In the plexrequests zip it sure does not.
Happy2Play 9811 Posted February 10, 2017 Posted February 10, 2017 In the plexrequests zip it sure does not. You getting the zip from here?
Happy2Play 9811 Posted February 10, 2017 Posted February 10, 2017 The instructions have to be modified to where you installed ombi unless you copied the content to C:\Ombi. Open the PlexRequests.zip and enter the Release folder, copy its contents to C:\Ombi or your custom installation folder.
Blueeyiz702 223 Posted February 10, 2017 Posted February 10, 2017 You getting the zip from here?yes, im telling you there is ombi.exe in the folder. Sent from my Rooted Z987 on the Deathstar via Tapatalk
