tidusjar 55 Posted February 9, 2017 Posted February 9, 2017 Guys, what settings are recommended? Early access preview, dev, stable? Or is this version the most recent Ombi for Emby https://emby.media/community/index.php?/topic/44267-ombi-for-emby/&do=findComment&comment=414788 ? Reason is that Ombi shows me an update in EAP branch. Is it safe to update to 2.1.1393? And can I download from within the website? So stable currently doesn't support Emby. Early Access Preview I would recommend as there is Emby support and more stable than dev, if you want bleeding edge then dev
sh0rty 727 Posted February 9, 2017 Posted February 9, 2017 (edited) So stable currently doesn't support Emby. Early Access Preview I would recommend as there is Emby support and more stable than dev, if you want bleeding edge then dev Thanks mate, recognized that the Appveyor link contains the actual zip. BTW this tool is so cool that I thought it's worth building an own Web page for my nginx reverse proxy. Edited February 9, 2017 by shorty1483 2
CBers 7554 Posted February 9, 2017 Posted February 9, 2017 Anyway to use this without a sever? thats the one item i don't have. Where do you run your Emby server? My question exactly... You don't need an Emby server to run Ombi, as it plugs into others services as well.
CBers 7554 Posted February 9, 2017 Posted February 9, 2017 Guys, what settings are recommended? Early access preview, dev, stable? Or is this version the most recent Ombi for Emby https://emby.media/community/index.php?/topic/44267-ombi-for-emby/&do=findComment&comment=414788 ? Reason is that Ombi shows me an update in EAP branch. Is it safe to update to 2.1.1393? And can I download from within the website? So stable currently doesn't support Emby. Early Access Preview I would recommend as there is Emby support and more stable than dev, if you want bleeding edge then dev The DEV branch works fine 1
rjay 21 Posted February 9, 2017 Posted February 9, 2017 What is the likelihood of a QPKG version of Ombi once the Emby Server support is part of the main branch? Currently run Emby/Sonarr/Radarr all native on the QNAP which is pretty handy thoughts?
tidusjar 55 Posted February 9, 2017 Posted February 9, 2017 What is the likelihood of a QPKG version of Ombi once the Emby Server support is part of the main branch? Currently run Emby/Sonarr/Radarr all native on the QNAP which is pretty handy thoughts? Usually once a new release goes out Stephane at QNAP is pretty quick in updating the QPKG. See here: https://forum.qnap.com/viewtopic.php?f=320&t=121568
sh0rty 727 Posted February 9, 2017 Posted February 9, 2017 Last from my side to be able to review my server behaviour. When activating newsletter, should it also inform for newly added episodes of series or just whole series and movies? When I first set up Ombi, I sent a test mail and it contained I guess my whole collection. New everytime Ombi sends the newsletter, it contains no series or movies. But I just added a new episode of a series.
tidusjar 55 Posted February 9, 2017 Posted February 9, 2017 Last from my side to be able to review my server behaviour. When activating newsletter, should it also inform for newly added episodes of series or just whole series and movies? When I first set up Ombi, I sent a test mail and it contained I guess my whole collection. New everytime Ombi sends the newsletter, it contains no series or movies. But I just added a new episode of a series. So the whole collection bit, that was expected. Regarding episodes, you need to make sure Episode Searching is enabled in the settings, Ombi will be able to detect which episodes have been added then. It will appear like: http://i.imgur.com/PIhsn33.png The series with episodes added beneath it. 1
rjay 21 Posted February 9, 2017 Posted February 9, 2017 Usually once a new release goes out Stephane at QNAP is pretty quick in updating the QPKG. See here: https://forum.qnap.com/viewtopic.php?f=320&t=121568 Perfect! Thanks Tidusjar I have so many of the QNAP forum threads now that I follow to grab the latest QPKG, its great. Looks like development is coming along quite well for the Emby integration, lots of great input
tidusjar 55 Posted February 9, 2017 Posted February 9, 2017 Perfect! Thanks Tidusjar I have so many of the QNAP forum threads now that I follow to grab the latest QPKG, its great. Looks like development is coming along quite well for the Emby integration, lots of great input Excellent! All of the input on this thread has helped a lot! The Emby community is pretty great! 2
Blueeyiz702 223 Posted February 9, 2017 Posted February 9, 2017 (edited) @Tidusjar@CBers off my laptop? thats where my Emby server is at. Is there a way to set it up on my laptop? I tried once and i messed it up,so i deleted everything. I think i missed a step or file to install. Edited February 9, 2017 by blueeyiz7021
tidusjar 55 Posted February 9, 2017 Posted February 9, 2017 @Tidusjar@CBers off my laptop? thats where my Emby server is at. Is there a way to set it up on my laptop? I tried once and i messed it up,so i deleted everything. I think i missed a step or file to install. Yeah you can install it on your laptop, Here is the .zip: https://ci.appveyor.com/project/tidusjar/requestplex/build/2.1.1401/artifacts Follow one of these guides depending on your OS: https://github.com/tidusjar/Ombi/wiki
Blueeyiz702 223 Posted February 9, 2017 Posted February 9, 2017 Or do any of you guys have a good VPS you recommend thats not to expensive?
Blueeyiz702 223 Posted February 9, 2017 Posted February 9, 2017 (edited) Yeah you can install it on your laptop, Here is the .zip: https://ci.appveyor.com/project/tidusjar/requestplex/build/2.1.1401/artifacts Follow one of these guides depending on your OS: https://github.com/tidusjar/Ombi/wiki ok,and how do i access it once its installed? got ombi folder installed ,but my Plexrequest.net folder is empty folder is empty? Edited February 9, 2017 by blueeyiz7021
tidusjar 55 Posted February 9, 2017 Posted February 9, 2017 ok,and how do i access it once its installed? got ombi folder installed ,but my Plexrequest.net folder is empty folder is empty? Depends on the OS, Once the Ombi folder is there, there is an executable called Ombi.exe. You need to run that, it is self hosting, so once that .exe is run then it will be hosted on port 3579.
Blueeyiz702 223 Posted February 9, 2017 Posted February 9, 2017 Depends on the OS, Once the Ombi folder is there, there is an executable called Ombi.exe. You need to run that, it is self hosting, so once that .exe is run then it will be hosted on port 3579.im not finding ombi.exe file and im running widows 7.Depends on the OS, Once the Ombi folder is there, there is an executable called Ombi.exe. You need to run that, it is self hosting, so once that .exe is run then it will be hosted on port 3579. Sent from my Rooted Z987 on the Deathstar via Tapatalk
tidusjar 55 Posted February 9, 2017 Posted February 9, 2017 im not finding ombi.exe file and im running widows 7. Sent from my Rooted Z987 on the Deathstar via Tapatalk Did you follow this guide:http://www.htpcguides.com/install-plex-requests-net-windows-system-service/ and download the zip file from here:https://ci.appveyor.....1401/artifacts ? Once the zip has been downloaded, unblock the zip file and then extract it somewhere. Go into the extracted folder and run Ombi.exe
Blueeyiz702 223 Posted February 9, 2017 Posted February 9, 2017 Sent from my Rooted Z987 on the Deathstar via Tapatalk
tidusjar 55 Posted February 9, 2017 Posted February 9, 2017 Can you run the .exe rather than the service? There seems to be an error and the .exe will tell you what the error is.
Blueeyiz702 223 Posted February 9, 2017 Posted February 9, 2017 Did you follow this guide:http://www.htpcguides.com/install-plex-requests-net-windows-system-service/ and download the zip file from here:https://ci.appveyor.....1401/artifacts ? Once the zip has been downloaded, unblock the zip file and then extract it somewhere. Go into the extracted folder and run Ombi.exe yes i followed all of it. Sent from my Rooted Z987 on the Deathstar via Tapatalk
Blueeyiz702 223 Posted February 9, 2017 Posted February 9, 2017 Can you run the .exe rather than the service? There seems to be an error and the .exe will tell you what the error is.im not finding exe file in ombi folder? Sent from my Rooted Z987 on the Deathstar via Tapatalk
CBers 7554 Posted February 9, 2017 Posted February 9, 2017 @ - I am running it under Windows 7 without any issues. Where did you install it to ?? I installed it into C:\ ProgramData\Ombi. Did you run all of the NSSM commands as per the instructions ??
Blueeyiz702 223 Posted February 9, 2017 Posted February 9, 2017 (edited) @ - I am running it under Windows 7 without any issues. Where did you install it to ?? yes i ran commands all was good. I installed it into C:\ ProgramData\Ombi. Did you run all of the NSSM commands as per the instructions ?? its installed under C:\Ombi Sent from my Rooted Z987 on the Deathstar via Tapatalk Edited February 9, 2017 by blueeyiz7021
CBers 7554 Posted February 9, 2017 Posted February 9, 2017 its installed under C:\Ombi And you run all of the NSSM commands ??
Blueeyiz702 223 Posted February 9, 2017 Posted February 9, 2017 And you run all of the NSSM commands ??yes Sent from my Rooted Z987 on the Deathstar via Tapatalk
