Spaceboy 2573 Posted July 8, 2017 Posted July 8, 2017 There should be an error in the console when starting. What isit? jeez i'm an idiot sometimes. it was still installed...
Spaceboy 2573 Posted July 8, 2017 Posted July 8, 2017 There should be an error in the console when starting. What isit? ok, any tips for setting this up connecting to emby through a reverse proxy?
Swynol 375 Posted July 10, 2017 Posted July 10, 2017 @@Spaceboy do you have a reverse proxy setup already? If so what are you using NGINX or certify?
Spaceboy 2573 Posted July 11, 2017 Posted July 11, 2017 @@Spaceboy do you have a reverse proxy setup already? If so what are you using NGINX or certify?all working with Caddy!
Swynol 375 Posted July 11, 2017 Posted July 11, 2017 awesome. sorry i was meant to say caddy not certify
ebr 16333 Posted July 22, 2017 Posted July 22, 2017 Is it possible to change the Ombi icon? I just cannot stomach the one it has now...
CBers 7554 Posted July 22, 2017 Posted July 22, 2017 Is it possible to change the Ombi icon? I just cannot stomach the one it has now... Yes. You can change it to whatever you want.
ebr 16333 Posted July 22, 2017 Posted July 22, 2017 Care to give me a clue? I looked in settings->customizations and see nothing. Searched this thread for 'icon' and came up blank...
CBers 7554 Posted July 22, 2017 Posted July 22, 2017 Sorry Eric, I'm thinking about Ombi in Organizr. I think Jamie has changed it in v3, for which a beta is due soon. 1
CBers 7554 Posted July 22, 2017 Posted July 22, 2017 Care to give me a clue? I looked in settings->customizations and see nothing. Searched this thread for 'icon' and came up blank... You could ask Jamie on his Gitter channel. https://gitter.im/tidusjar/Ombi
lexisdude 145 Posted July 24, 2017 Posted July 24, 2017 Not sure if this has been addressed or not. Doing an actor search gives mixed results and doesn't carry all titles associated with themAs an example:Arnold SchwarzeneggerIn OMBI (no further listings)From the Arnold Schwarzenegger page @ https://www.themoviedb.org/person/1100-arnold-schwarzenegger So why aren't the rest of the titles being shown? Is there a display limit to titles?
tidusjar 55 Posted July 24, 2017 Posted July 24, 2017 That is correct, We only show the first 10 movies returned from the API IIRC. The reason for this was that each movie required two API calls, one to get the movies by actor and the other to get the actual movie information. If we displayed the whole result then we could potentially reach the API limit (per IP address) 1
lexisdude 145 Posted July 24, 2017 Posted July 24, 2017 (edited) That is correct, We only show the first 10 movies returned from the API IIRC. The reason for this was that each movie required two API calls, one to get the movies by actor and the other to get the actual movie information. If we displayed the whole result then we could potentially reach the API limit (per IP address) That makes sense. Is there a way that for actors it scrapes either the most recent titles or what the actors are most known for? That would sure look better and be more useful than seeing shows that nobody probably wants to watch anyhow. And if working from the top - down; having a better chance to hide titles already present if hiding already available titles. Edited July 24, 2017 by lexisdude
lexisdude 145 Posted July 25, 2017 Posted July 25, 2017 Ok - I really love this gem of a program now that I have been messing around with it. Kudos to everyone that is involved in the project - I will send some beer money when I can. It seems to work almost flawlessly in both Radarr and Sonarr which are also amazing programs in their own respects. I know that the interfacing with headphones is beta and surely a little shaky - but moreso than not I have noticed the api causing more "none - none - none" adds than anything. I got 2 albums to work but the rest have either produced empty slots through the headphones API or state success in adding ; and nothing shows up on the headphones web page. When it is going to fail if it seems to immediately add the album - the two times that it worked it waited until headphones polled the data online and put the requested album in the "wanted" tab. I don't want to automatically assume it's Ombi because headphones is more frusterating than it is satisfying. Have there been other people reporting this sort of problem? 1
CBers 7554 Posted July 25, 2017 Posted July 25, 2017 Further questions/suggestions should be made on the official OMBI forums. https://forums.ombi.io
Jdiesel 1435 Posted July 31, 2017 Posted July 31, 2017 Anyone take a stab at testing the .NETCore version? I just had a look and it is foreign to me. Looks like NGINX or Apache will be a minimum requirement.
tidusjar 55 Posted July 31, 2017 Posted July 31, 2017 Where you reading this? It's self hosting but you can put it behind a proxy. I wouldn't recommend V3 as I'm still heavily mid development and breaking changes will happen. 1
Jdiesel 1435 Posted July 31, 2017 Posted July 31, 2017 (edited) Where you reading this? It's self hosting but you can put it behind a proxy. I wouldn't recommend V3 as I'm still heavily mid development and breaking changes will happen. Likely just me being uninformed on .net. I tried to self host it but I seem to be having issues at this point and have not done enough research into. I grabbed the build from: https://ci.appveyor.com/api/buildjobs/ex6551fhbi6un66m/artifacts/Ombi_ubuntu.zip Do I need to publish the build before I run it? If I try to publish I get an error stating that the project or solution can't be found. If I try to run it I get: /opt/ombi_dotnetcore$ dotnet ombi.dll No executable found matching command "dotnet-ombi.dll" My apologies if I am completely off as this is my first running hosting anything with .net core Edited July 31, 2017 by Jdiesel
tidusjar 55 Posted July 31, 2017 Posted July 31, 2017 Ah ok. If you are on Ubuntu you need to chmod +X or something to make it an executable. But just run .\ombi 1
Jdiesel 1435 Posted July 31, 2017 Posted July 31, 2017 Ah ok. If you are on Ubuntu you need to chmod +X or something to make it an executable. But just run .\ombi That did the trick! Thanks
CBers 7554 Posted July 31, 2017 Posted July 31, 2017 @@Jdiesel - you can always post on the Official Ombi forums. https://forums.ombi.io Thanks.
tidusjar 55 Posted July 31, 2017 Posted July 31, 2017 Please remember it's no where near finished yet!
BonzTM 0 Posted September 25, 2017 Posted September 25, 2017 (edited) Is there a known Emby user sync issue when users change their passwords? Incorrect username/password after an Emby password change. I've had 2 such issues so far to no resolve. Edited September 25, 2017 by BonzTM
CBers 7554 Posted November 18, 2017 Posted November 18, 2017 Ombi now has a DISCORD channel. https://discord.gg/H2v7MmB
CBers 7554 Posted May 14, 2018 Posted May 14, 2018 Ombi now has mobile apps for both iOS and Android. iOS https://itunes.apple.com/us/app/ombi/id1335260043?platform=iphone&preserveScrollPosition=true&platform=iphone#platform/iphone&platform=iphone Android https://play.google.com/store/apps/details?id=com.tidusjar.Ombi 2
