rjay 21 Posted April 4, 2017 Posted April 4, 2017 Hi. They is no longer the case. Can you please post that on the QNAP find like forums? Thanks, done Mentioned they might want to either remove the prereq possibly or expand it to recognise either the Plex or Emby qpkgs as being installed. For reference thread link below: https://forum.qnap.com/viewtopic.php?f=320&t=121568&p=607127#p607127
rjay 21 Posted April 4, 2017 Posted April 4, 2017 @@tidusjar the response was that the prereq will be removed when the next version comes out and QNAP_Stephane creates the new QPKG
Diedrich 380 Posted April 4, 2017 Posted April 4, 2017 (edited) @@tidusjar From the changelog, it looks like we should upgrade to EAP 1608? Are you doing some architectural changes in the versions after that? The changelog seems to indicate instability above 1608. Edited April 4, 2017 by dvgmar
CBers 7554 Posted April 4, 2017 Posted April 4, 2017 It might be easier to speak to @@tidusjar (Jamie) over at his Gitter channel. 1
schmitty 66 Posted April 5, 2017 Posted April 5, 2017 Hi, I have installed Ombi and gone to localhost:3579, and get ERR_CONNECTION_REFUSED. Any suggestions?
Logos302 86 Posted April 5, 2017 Posted April 5, 2017 Hi, I have installed Ombi and gone to localhost:3579, and get ERR_CONNECTION_REFUSED. Any suggestions? Firewall is the most likely cause, provided it's actually running. I just set it up yesterday so I'm just learning my self.
schmitty 66 Posted April 5, 2017 Posted April 5, 2017 I thought that myself, might have to check it again. Sent from my iPhone using Tapatalk
schmitty 66 Posted April 5, 2017 Posted April 5, 2017 Nope. Just added an exception for Ombi using port 3579... still no luck. Sent from my iPhone using Tapatalk
tidusjar 55 Posted April 5, 2017 Posted April 5, 2017 Nope. Just added an exception for Ombi using port 3579... still no luck. Sent from my iPhone using Tapatalk https://github.com/tidusjar/Ombi/wiki/FAQ#i-am-having-issues-allowing-ombi-through-my-firewall
schmitty 66 Posted April 5, 2017 Posted April 5, 2017 Just tried it. Still not working. Sent from my iPhone using Tapatalk
SuperPotatoMen 41 Posted April 9, 2017 Author Posted April 9, 2017 (edited) Hey guys! There is a new stable release. Just a minor bugfix release really! Download link: https://github.com/tidusjar/Ombi/releases I would also like to let people know about our forum now! check it out! https://forums.ombi.io Changes - Reworked the Sonarr integration (before it was a bit hit and miss), here are a few of the fixed items from this change: - If a season is requested we will tell Sonarr to look for a season pack rather than searching each individual episode - I've also fixed all the issues where seasons/episodes wasn't being monitored correctly and searched for. - Fixed a load of bugs around the newsletter, especially related to how we find episodes to put into the newsletter. Edited April 9, 2017 by SuperPotatoMen 2
PrincessClevage 175 Posted April 18, 2017 Posted April 18, 2017 (edited) Hey guys! There is a new stable release. Just a minor bugfix release really! Download link: https://github.com/tidusjar/Ombi/releases I would also like to let people know about our forum now! check it out! https://forums.ombi.io Changes - Reworked the Sonarr integration (before it was a bit hit and miss), here are a few of the fixed items from this change: - If a season is requested we will tell Sonarr to look for a season pack rather than searching each individual episode - I've also fixed all the issues where seasons/episodes wasn't being monitored correctly and searched for. - Fixed a load of bugs around the newsletter, especially related to how we find episodes to put into the newsletter. Will this be released as a plugin for Emby available from the plugin catalogue? Edited April 18, 2017 by PrincessClevage
Happy2Play 9811 Posted April 18, 2017 Posted April 18, 2017 Will this be released as a plugin for Emby available from the plugin catalogue? I highly doubt it will ever be.
CBers 7554 Posted April 18, 2017 Posted April 18, 2017 Will this be released as a plugin for Emby available from the plugin catalogue? No, as you add Emby to Ombi not the other way round.
lorac 119 Posted June 10, 2017 Posted June 10, 2017 I tried to set this up but not having any luck. The links seem to be broken for the images and ps1 file as well from the how to so it's possible I'm missing a step. I did run the program as an administrator. Using Windows Server 2016.
SuperPotatoMen 41 Posted June 10, 2017 Author Posted June 10, 2017 You didn't unblock the zip file before unzipping. If you dont do that step, you got a crash when you try to start ombi. There are 3 warnings in my how with do not skip this step. Pleas follow the how to a little bit better. There are posted 3 solution to fix this problem.
lorac 119 Posted June 10, 2017 Posted June 10, 2017 And as a stated there are no images in the howto in the forums. I downloaded the file, right click when to properties and selected unblock and then unzipped it.
SuperPotatoMen 41 Posted June 10, 2017 Author Posted June 10, 2017 Can you post the full logs instead of a printscreen? I Miss to many log lines now.
SuperPotatoMen 41 Posted June 10, 2017 Author Posted June 10, 2017 (edited) Hmm I see now that the how to is a little bit broken. Give me a sec to fix that Edited June 10, 2017 by SuperPotatoMen
lorac 119 Posted June 10, 2017 Posted June 10, 2017 i also would have used the powershell script to try to fix the issue but I get the following error when I go to download it: InformationThe selected attachment does not exist anymore. https://forums.ombi.io/download/file.php?id=7 TIA for your help. It sounds like a nice addon. 2017-06-10.log
SuperPotatoMen 41 Posted June 10, 2017 Author Posted June 10, 2017 (edited) i also would have used the powershell script to try to fix the issue but I get the following error when I go to download it: InformationThe selected attachment does not exist anymore. https://forums.ombi.io/download/file.php?id=7 TIA for your help. It sounds like a nice addon. Did you unblocked the files before unzipping? Edited June 10, 2017 by SuperPotatoMen
lorac 119 Posted June 11, 2017 Posted June 11, 2017 Yes but that was ineffective. I used 7zip instead which makes things easier. I have it installed now. Haven't quite figured out how it all works but we'll get their.
Spaceboy 2573 Posted July 8, 2017 Posted July 8, 2017 Did you unblocked the files before unzipping? exactly the same issue. I've had this installed before so I know what needs doing but nothing I can do will get it to run without crashing on start 1
tidusjar 55 Posted July 8, 2017 Posted July 8, 2017 exactly the same issue. I've had this installed before so I know what needs doing but nothing I can do will get it to run without crashing on start There should be an error in the console when starting. What isit? 1
