MSattler 390 Posted March 7, 2017 Posted March 7, 2017 Oh yeah sorry it's been localized for other languages! It's this line: <h4>@string.Format(UI.Search_Paragraph, Model.Emby ? "Emby" : "Plex")</h4> Replace it with what you want e.g. <h4>Welcome to my server!</h4> So that changed for the area when the user is logged in. The initial page that loads where you login is \Userlogin\cindex.html. Is this the right portion to edit: <p> @UI.UserLogin_Paragraph <span title="@UI.UserLogin_Paragraph_SpanHover"><i class="fa fa-question-circle"></i></span> </p>
tidusjar 55 Posted March 7, 2017 Posted March 7, 2017 Oh sorry I was looking at the search page, I misunderstood. Yes that is correct
MSattler 390 Posted March 7, 2017 Posted March 7, 2017 Oh sorry I was looking at the search page, I misunderstood. Yes that is correct Hmm, that did not do it. I'm just trying to minimize how much data the front page gives away. =)
Overseer 66 Posted March 9, 2017 Posted March 9, 2017 Like that the landing page is now working for Emby.
MSattler 390 Posted March 9, 2017 Posted March 9, 2017 Like that the landing page is now working for Emby. New version? Hasnt been working for me...
Overseer 66 Posted March 9, 2017 Posted March 9, 2017 (edited) Yep, running v2.1.1499 EAP released today. Edited March 9, 2017 by Overseer
MSattler 390 Posted March 9, 2017 Posted March 9, 2017 Yep, running v2.1.1499 EAP released today. It only works for me if I make it visible to users before login. My preference would be that it is shown to the user after the login, which currently doesn't work. Still wish I could figure out how to change the text on the login page.
simonk83 7 Posted March 9, 2017 Posted March 9, 2017 Still wish I could figure out how to change the text on the login page. That's something worth adding to Ombi anyway I reckon. Makes a great deal of sense to be able to customise the login/landing pages.
SuperPotatoMen 41 Posted March 9, 2017 Author Posted March 9, 2017 Maybe you like this idea: https://github.com/tidusjar/Ombi/issues/1106 3
MSattler 390 Posted March 11, 2017 Posted March 11, 2017 Oh sorry I was looking at the search page, I misunderstood. Yes that is correct when you get a chance, I'm still trying to figure out how to change the content on the initial login page. Thanks!
Happy2Play 9811 Posted March 11, 2017 Posted March 11, 2017 (edited) @@MSattler What exactly you trying to do? That section seems like a simple edit. Original username.cshtml <div class="home"> <h1>@UI.UserLogin_Title</h1> <div> <p> @string.Format(UI.UserLogin_Paragraph, Html.GetMediaServerName().ToHtmlString()).ToString() </p> </div> My quick edit *Note you have to restart Ombi if you are editing while it is still running. <div class="home"> <h1>My Ombi Login</h1> <div> <p> What are you trying to do? </p> </div> Edited March 11, 2017 by Happy2Play
MSattler 390 Posted March 11, 2017 Posted March 11, 2017 @@MSattler What exactly you trying to do? That section seems like a simple edit. Original username.cshtml <div class="home"> <h1>@UI.UserLogin_Title</h1> <div> <p> @string.Format(UI.UserLogin_Paragraph, Html.GetMediaServerName().ToHtmlString()).ToString() </p> </div> My quick edit *Note you have to restart Ombi if you are editing while it is still running. <div class="home"> <h1>My Ombi Login</h1> <div> <p> What are you trying to do? </p> </div> Sweet, that works. I was trying to edit the index.chtml file. Thanks! Works splendid now!
pr3dict 33 Posted March 17, 2017 Posted March 17, 2017 This looks extremely promising; a long awaited request. I can't wait for it to be out of beta
n1ete 0 Posted March 18, 2017 Posted March 18, 2017 so i am looking forward to use ombi with emby on my ubuntu 16.04 headless server too. i installed it and after i get to the webinterface at http://localhost:3579 i am greeted with an plex login? how can i integrate it with emby?
CBers 7554 Posted March 18, 2017 Posted March 18, 2017 i installed it and after i get to the webinterface at http://localhost:3579 i am greeted with an plex login? how can i integrate it with emby? Are you on the correct version, as Emby support is only available in the EAP or DEVELOP branches. Goto the About page and it will tell you the version and branch.
Diedrich 380 Posted April 1, 2017 Posted April 1, 2017 2.2.1596 Newsletter is looking good! The logo comes through and I'm getting new movie notifications perfectly. (as you know, there is still an issue with episodes being included in the newsletter) But yeah, you guys are doing a great job. Keep it up!
tidusjar 55 Posted April 1, 2017 Posted April 1, 2017 THANKS! Yeah there are still some small issues to iron out, but thanks everyone for their help and support It was 100% worth adding Emby support, you guys are great! 5
NeonGOD 3 Posted April 3, 2017 Posted April 3, 2017 I think i will give this a go.. i still need to install the EAP Branch or ??
tidusjar 55 Posted April 3, 2017 Posted April 3, 2017 (edited) I think i will give this a go.. i still need to install the EAP Branch or ?? https://github.com/tidusjar/Ombi/releases/latest Edited April 3, 2017 by ebr Fixed link
Diedrich 380 Posted April 3, 2017 Posted April 3, 2017 (edited) If I manually run a task (Newsletter) does that then reset the clock for the next time the task will run? On second look - I don't see a scheduled task for Newsletter. When does that get sent? Is the frequency something we can define? 7 days, 3 days, on Monday, on Friday, etc... Edited April 3, 2017 by dvgmar
tidusjar 55 Posted April 3, 2017 Posted April 3, 2017 If I manually run a task (Newsletter) does that then reset the clock for the next time the task will run? On second look - I don't see a scheduled task for Newsletter. When does that get sent? Is the frequency something we can define? 7 days, 3 days, on Monday, on Friday, etc... It does not reset the clock. The newsletter is run via a CRON expression, it's in the schedule settings page.
Animosity022 6 Posted April 3, 2017 Posted April 3, 2017 I shared this issue on Ombi's github and figured I'd cross post here as well. I'm trying to get logged in via "Guest" user in Ombi and that seems to fail while "Users" work fine. I'm guessing it's because that Guest cannot log in to my server locally as I can see the "Auth failed" if I try to log them in directly to my server. If they log in via the Emby Connect App, they can see my server just fine. Do they need user accounts on my system to actually work via Ombi instead of the Guest Account? Issue is here -> https://github.com/tidusjar/Ombi/issues/1331
NeonGOD 3 Posted April 3, 2017 Posted April 3, 2017 https://github.com/tidusjar/Ombi/releases/latest Thank You Thats what i expected, reading the changlog
rjay 21 Posted April 4, 2017 Posted April 4, 2017 Morning @@tidusjar! so it looks like we are all live for the latest version being compatible with Emby? Downloaded the latest Qpkg for QNAP and it comes up with an error on install stating it requires Plex to be installed as a prereq. Is this the case now that it is able to use Ombi? Wasn't sure if I should post this here or the QNAP Ombi thread thanks
tidusjar 55 Posted April 4, 2017 Posted April 4, 2017 Hi. They is no longer the case. Can you please post that on the QNAP find like forums?
