simonk83 7 Posted February 25, 2017 Posted February 25, 2017 Login will be determined by your Authentication Settings. Authentication Settings -Enable User Authentication -Require users to login with their passwords God, sorry. The User Auth had dropped off as is turns out and it didn't even cross my mind to check there. Fine now
Overseer 66 Posted February 25, 2017 Posted February 25, 2017 So, I just cleaned out my Ombi folder and started from scratch with EAP v.1462. I am still getting the error when running the Radarr cacher Failed caching queued items from Radarr Ombi.Services.Jobs.RadarrCacher Error 2/24/2017 8:07:33 PM with the same error in my log as before. Searching for Alien: Covenant in Ombi does not show it already to my Radarr que. I am running Radarr nightly builds with the latest at 0.2.0.393. @@simonk83 What version of Radarr are you running where this works for you?
simonk83 7 Posted February 25, 2017 Posted February 25, 2017 So, I just cleaned out my Ombi folder and started from scratch with EAP v.1462. I am still getting the error when running the Radarr cacher Failed caching queued items from Radarr Ombi.Services.Jobs.RadarrCacher Error 2/24/2017 8:07:33 PM with the same error in my log as before. Searching for Alien: Covenant in Ombi does not show it already to my Radarr que. I am running Radarr nightly builds with the latest at 0.2.0.393. @@simonk83 What version of Radarr are you running where this works for you? I'm on the latest nightly for Radarr. Does it connect ok in the Ombi Radarr settings? Pulls down your qualities etc ok?
Overseer 66 Posted February 25, 2017 Posted February 25, 2017 Yeah, it connected with the API ok in the Ombi Radarr settings page. Everything pulled down as expected. Just can't run the Radarr cacher.
simonk83 7 Posted February 25, 2017 Posted February 25, 2017 Yeah, it connected with the API ok in the Ombi Radarr settings page. Everything pulled down as expected. Just can't run the Radarr cacher. Hmm, might need to wait for the devs I think
Overseer 66 Posted February 25, 2017 Posted February 25, 2017 I will state that starting the latest EAP from scratch and going through the initial set-up was pretty nice and very smooth. Liked logging in and seeing all my Emby users already on the Users screen. Really looking forward to the newsletter getting fixed.
Overseer 66 Posted February 25, 2017 Posted February 25, 2017 (edited) Hmmm... was playing around with the 'In Theaters' and 'Coming Soon' under 'Suggestions' on the Search page for movies. I have the Trailers plug-in installed so that we can watch upcoming Trailers and it appears that Ombi picks up those Trailers as AVAILABLE for movie watching in Emby. For example, Nocturnal Animals is a trailer available to view in via the Trailers plugin. Ombi shows it as AVAILABLE as a movie. I actually don't have that movie. https://github.com/tidusjar/Ombi/issues/1188 Like the 'Most Anticipated Shows' under the TV Shows suggestions search page. Definitely added a few through shows from there. Edited February 25, 2017 by Overseer 1
sh0rty 727 Posted February 25, 2017 Posted February 25, 2017 (edited) Hmmm... was playing around with the 'In Theaters' and 'Coming Soon' under 'Suggestions' on the Search page for movies. I have the Trailers plug-in installed so that we can watch upcoming Trailers and it appears that Ombi picks up those Trailers as AVAILABLE for movie watching in Emby. For example, Nocturnal Animals is a trailer available to view in via the Trailers plugin. Ombi shows it as AVAILABLE as a movie. I actually don't have that movie. https://github.com/tidusjar/Ombi/issues/1188 Like the 'Most Anticipated Shows' under the TV Shows suggestions search page. Definitely added a few through shows from there. This is the reason I deinstalled BlurN Plugin. Edited February 25, 2017 by shorty1483
Happy2Play 9811 Posted February 25, 2017 Posted February 25, 2017 Hmm, I don't see "Available" for Trailers or Blurn plugin items. v2.1.1462
sh0rty 727 Posted February 26, 2017 Posted February 26, 2017 Hmm, I don't see "Available" for Trailers or Blurn plugin items. v2.1.1462 Funny, huh? I even saw BlurN Releases on the Ember Main page as new movies.
G1zm0 13 Posted February 26, 2017 Posted February 26, 2017 (edited) Is there a noob guide how to install Ombi in an Docker on my Synology?I found this: https://github.com/rogueosb/docker-ombiBut as I said, kinda new on the docker thing.. Edited February 26, 2017 by G1zm0
CBers 7554 Posted February 26, 2017 Posted February 26, 2017 Is there a noob guide how to install Ombi in an Docker on my Synology? I found this: https://github.com/rogueosb/docker-ombi But as I sayd, kinda new on the docker thing.. I don't know dockers, but there are install instructions here: https://github.com/tidusjar/Ombi/wiki
troyscorer 3 Posted February 28, 2017 Posted February 28, 2017 im lost, i installed Ombi Early Access for use with my Emby Server and the first screen i get is this. Ubuntu 16.04 I dont use Plex as i use EMBY.
SuperPotatoMen 41 Posted February 28, 2017 Author Posted February 28, 2017 im lost, i installed Ombi Early Access for use with my Emby Server and the first screen i get is this. Ubuntu 16.04 I dont use Plex as i use EMBY. If you get that screen, you didn't download EAP version. Pleas use the download buttons on the github page.
Diedrich 380 Posted February 28, 2017 Posted February 28, 2017 im lost, i installed Ombi Early Access for use with my Emby Server and the first screen i get is this. https://emby.media/community/index.php?/topic/44267-Ombi-for-Emby&do=findComment&comment=414788 1
troyscorer 3 Posted March 3, 2017 Posted March 3, 2017 I got this to work, for the record i did install the stable release, started the service, stopped the service, deleted the /opt/ombi directory and recopied the EA files into it before i posted this. But when i came back (finally) today to try again, it was running the EA files and everything worked... That is until i updated to the latest version and the service just stops after the initial startup wizard is completed with no log entries. Ive uninstalled, i will try again when you merge emby support into stable. Thanks for the help.
Diedrich 380 Posted March 4, 2017 Posted March 4, 2017 Are there still issues open for: Receiving a request for a movie that is already in the Radarr Wanted list. Not auto-marking a movie is ready when it was requested and downloaded this morning and now it's night.
CBers 7554 Posted March 4, 2017 Posted March 4, 2017 @ - all of the Ombi issues are listed here: https://github.com/tidusjar/Ombi/issues
Diedrich 380 Posted March 4, 2017 Posted March 4, 2017 Yeah, I was just being lazy and was curious if anyone knew offhand if they were too experiencing those issues. 1
tidusjar 55 Posted March 6, 2017 Posted March 6, 2017 Hi Guys, Sorry about the lack of response recently, i've been incredibly busy and i've not been able to spend as much time on Ombi as I would have liked to. There is still an issue with the newsletter and I am aware of this, It's something that I am struggling with, when we call Emby to get more information about a media item, Ombi is receiving an error from Emby. I did post this on Emby's Github but since then I am unable to recreate this myself... But I can see from the logs that other people are still getting this issue so I need to spend some more time investigating why this has happened. 5
Diedrich 380 Posted March 7, 2017 Posted March 7, 2017 (edited) Hi Guys, Sorry about the lack of response recently, i've been incredibly busy Those infants are a bit of a handful, huh? Mine's 2.5 but I remember those days all too well. Edited March 7, 2017 by dvgmar
MSattler 390 Posted March 7, 2017 Posted March 7, 2017 Is Hi Guys, Sorry about the lack of response recently, i've been incredibly busy and i've not been able to spend as much time on Ombi as I would have liked to. There is still an issue with the newsletter and I am aware of this, It's something that I am struggling with, when we call Emby to get more information about a media item, Ombi is receiving an error from Emby. I did post this on Emby's Github but since then I am unable to recreate this myself... But I can see from the logs that other people are still getting this issue so I need to spend some more time investigating why this has happened. Is there a way to change the content of the front page? So I can change where it says: LoginWant to watch a movie or tv show but it's not currently on Emby? Login below with your username and password! Thanks, Marcus
tidusjar 55 Posted March 7, 2017 Posted March 7, 2017 Is Is there a way to change the content of the front page? So I can change where it says: LoginWant to watch a movie or tv show but it's not currently on Emby? Login below with your username and password! Thanks, Marcus You would have to manually change the html in the .cshtml file. You can find this in Views/Search/Index.cshtml
MSattler 390 Posted March 7, 2017 Posted March 7, 2017 You would have to manually change the html in the .cshtml file. You can find this in Views/Search/Index.cshtml Hmm I looked there but saw nothing in plain text that resembles that. You sure it's not actually in a dll? Thanks!
tidusjar 55 Posted March 7, 2017 Posted March 7, 2017 Hmm I looked there but saw nothing in plain text that resembles that. You sure it's not actually in a dll? Thanks! Oh yeah sorry it's been localized for other languages! It's this line: <h4>@string.Format(UI.Search_Paragraph, Model.Emby ? "Emby" : "Plex")</h4> Replace it with what you want e.g. <h4>Welcome to my server!</h4>
