clarkss12 304 Posted January 26, 2017 Posted January 26, 2017 (edited) Testing new server running on low powered Linux box and using my 2016 Samsung TV KU6500 as my client. Video is pausing and stuttering. My unlearned opinion, it should be "Direct Playing". see attached. EDIT: Never mind, I forgot to go into the settings and change the subtitles to "none". It is "Direct Playing", now. thanks. MacArthur mediainfo.txt MacArthur server log.txt MacArthur transcoding log.txt Edited January 26, 2017 by clarkss12 1
Luke 42240 Posted January 26, 2017 Posted January 26, 2017 Yes good observation as Tizen does not support dvd_subtitles @@SamES
SamES 1084 Posted January 26, 2017 Posted January 26, 2017 Yes, I was playing with this last night. I can enable support for them, but they either don't display at all, or "YYY" displays as the subtitle at the correct timing, but always "YYY". Not sure what else to try as they definitely play via DLNA/USB?
